2007 Road King No Power After Engine Mount
Battery is charged and good. Behavior is that when I turn the ignition switch nothing happens - not in accessory or run position.
I'm wondering if somehow I borked up the voltage regulator or wiring. I suppose it's possible something was crushed but I checked the wires while the oil cooler and regulator were bolted in and they were moving around so I don't think that's the case.
Fuses are good so that's not an issue.
Is there something in there which I may have missed? The last thing I did before final mounting of the VR and oil cooler was a test start to make sure everything was working.
Then today want to do a test ride and nothing.
Any suggestions no matter how obvious appreciated!
How much did you take a part to do this? Removed volt reg, removed mount, removed? For any reason did you take the ground off? Maxi fuse is good? If it is all dark, maxi fuse, ignition, or battery cables.
