2000 Ultra Classic - Sputtering/ Hesitation
Old May 11, 2025 | 08:39 AM
gilman1's Avatar
gilman1
Default 2000 Ultra Classic - Sputtering/ Hesitation
Have a 2000 that has a bad hesitation and bucks, and kicks! Replaced fuel pump, hoses, filter. Have power commander 1. Motor bumped up to 98 ci. Also, at startup rpms jump to 3k! Happens about 3x then will go to 1k after 2nd, 3rd time starting. Had this converted to trike so I can keep riding! Ready to burn this mother####@$ up!
Old May 11, 2025 | 08:52 AM
hattitude's Avatar
hattitude
It could be anything from an adjustment on the MM EFI system is needed, to the possibility that the Power Commander 1 has failed, or it could be several other possible issues in between.
I believe an understanding of the MM EFI system will be key to this issue's diagnosis.
If you don't understand the MM EFI system, or do your own work, I would seek out an independent shop that understands the MM EFI system on Harleys and have them give it a look.
Good luck with your repair..
PS- If you should decide to "burn this mother####@$ up!", you should look into one of the newer HD trikes to replace it. They have the newer Delphi EFI system, and I understand they are very nice as trikes go..
Old May 11, 2025 | 02:19 PM
gilman1's Avatar
gilman1
I did! 48k wasn't in the budget. Had mine since new that's why I had it converted.
jigoe007
Mar 30, 2022 11:09 AM
HeavysHippie
Sep 25, 2021 02:05 PM
gary p
Jun 5, 2014 05:34 PM
svarnster
May 3, 2012 12:18 AM
zz50200
Jul 28, 2010 07:20 AM
