Speedometer keeps blowing fuses
Old Jul 22, 2025 | 11:55 AM
Jb054290's Avatar
Jb054290
Stage I
Default Speedometer keeps blowing fuses
I have a 2006 road king and the speedometer stopped working. Figured out it's blowing fuses. I took a multimeter and put where the fuse goes and it's only getting 12.2v to that spot. Any ideas why it's getting the right voltage to the fuse box but still blowing fuses?
Old Jul 22, 2025 | 01:34 PM
Keithhu's Avatar
Keithhu
Intermittent pinched wire somewhere, I'm guessing.
Old Jul 22, 2025 | 01:46 PM
Mr. Mike's Avatar
Mr. Mike
You’ll have 12 volts until you put a load into the circuit. The Speedo is just that. I’d surmise something inside the speedometer is drawing more current than the fuse is rated for. Look at all visible wired or soldered areas. You might find a pinched wire, bare wire or even a shorted light bulb can do it.
Or- could be the speedometer is in need of repair or replacement.
Old Jul 22, 2025 | 02:20 PM
im's Avatar
im
Sometimes a speedometer is on a fuse that controls more than 1 item.
When a fuse blows it generally means that either a short circuit is present or there is a high demand item on that line.
Since the speedometer has a relationship with turn signals and a few warning lights, perhaps there is something else going on at this time.
By chance does your model have a wire loom under rear fender?
Reason:
A lowered rear end of bike makes such a motorcycle more prone to tire scrub against wire loom that is under rear fender.
If that wire loom is scrubbed and damaged then a short circuit becomes more probable.
Old Jul 22, 2025 | 02:22 PM
im's Avatar
im
Is motorcycle operational?
Have you taken voltage at battery? at rest? at high rpm?
Just trying to rule out a regulator problem too.
KB56
Electrical/Lighting/Alarm
Jun 4, 2025 11:46 AM
tankzilla
Aug 27, 2019 11:28 AM
Boots3139
Aug 14, 2018 09:19 PM
cromagnon
Jul 11, 2015 09:56 AM
ac
Jan 26, 2010 02:29 PM
