Speedo keeps blowing fuse
Old May 27, 2018 | 09:44 PM
Boots3139's Avatar
Boots3139
2nd Gear
Default Speedo keeps blowing fuse
I’ve got a 01 police edition Road King. The fuse for the speedo, brake light and turns keeps blowing. The tach and headlight and running light still work. I’ve chased all the wiring, there is no bad wiring. You can have the bike sit and idle or have the ignition switch in the run position. Will not blow the fuse. As soon as you stated to move it will blow it. Any idea or a direction to head
Old May 27, 2018 | 10:09 PM
run1fsr's Avatar
run1fsr
Have you disconnected the speedometer, then try again? That would rule out or confirm the speedometer as a cause.
Old May 27, 2018 | 10:19 PM
Boots3139's Avatar
Boots3139
2nd Gear
Just did that and still blow the fuse. When I take off. I’m not using the brakes or the turn sighs
Old May 27, 2018 | 10:44 PM
run1fsr's Avatar
run1fsr
So it's not the speedometer. Now, one by one, unplug each connector to everything on that same fuse until you rule each circuit out. Do you have a service manual with a wiring schematic? That diagram will help trace it all back to a common source.
Old May 27, 2018 | 11:35 PM
Boots3139's Avatar
Boots3139
2nd Gear
Ok. I’ll give it a try. Do you know a good place to get a Service manual
Old May 28, 2018 | 04:18 AM
GregGillette's Avatar
GregGillette
Try removing the bulbs for lights that are affected when fuse blows as there may be a shorted filament to ground and if fuse stays intact when ride, work your way back to offending light
Old May 28, 2018 | 05:41 AM
skratch's Avatar
skratch
if you go here: https://serviceinfo.harley-davidson....cle/lookupForm you can enter your vin and then pull up some good stuff, like your wiring diagrams, owner's manuals, etc. if you sign up for a free account, you can also access this information for other bikes as well. the account is free. there's a lot more you can get if you have a subscription, only the subscription is available only to those overseas. but still an excellent resource none the less.
Old May 28, 2018 | 06:21 AM
Touten2's Avatar
Touten2
Check the wire supplying the front fender light. The wire goes into the fender and can get some slack in it, and the tire wears the insulation off of the wire, causing a short.
Old May 28, 2018 | 07:57 AM
run1fsr's Avatar
run1fsr
Buy a used one off eBay
Old Aug 14, 2018 | 09:19 PM
Mark Collins's Avatar
Mark Collins
Stage I
Default Me Too on a 2000 Electra Glide
Did you ever fix the problem?
CVORoadKing2013
2014-2024 Touring Models
14
Nov 30, 2018 08:17 AM
Michael32744
Electrical/Lighting/Alarm
Nov 21, 2018 02:30 PM
dguse
Feb 1, 2009 02:47 PM
DougsDyna
Oct 22, 2007 09:10 PM
RANDIT
Jul 17, 2007 09:40 PM
