is it the stereo or speakers?
Old Jul 27, 2025 | 08:51 PM
Robertbc3141's Avatar
Robertbc3141
Default is it the stereo or speakers?
I have (I think) the stock Harley Davidson Harman Kardon CD stereo system in my new to me 2008 Electra Glide Ultra Classic - yes a CD.
I've never been much of an audiophile, my previous 10 or so Hondas didn't even have music, but this isn't a very good sounding system.
Is the limiting factor here the stereo (it's amp) or the speakers?
Yes I like to replace one or the other before both.
I don't think I need an extra amp talked about in the touring pack - what would like a better stereo maybe with a bigger amp in the unit?
Or would that not do any good with the same speaker?
and similarly would replacing the speakers not do any good with the same stereo?
The CD skips anyway so I'm inclined to replace that.
Yes I could replace everything and probably be happy but as you can see I'm a cheapskate ( I bought a 2008, not a 2025).
What would be the first thing you would replace and with what?
Old Jul 27, 2025 | 10:28 PM
NorthWestern's Avatar
NorthWestern
Why did you post this in the LiveWire subforum?
To answer your questions, you NEED an amp and new speakers at a minimum. If you go over to the stereo sub-forum and read, you will find this to be true. Many of us have made this upgrade.
Old Jul 28, 2025 | 05:50 AM
MURPHCC1's Avatar
MURPHCC1
Money pit rabbit hole......
YES you need a new AMP, RADIO and SPEAKERS.
Hit the Audio section and ask away.
I've used SONY radios, BIKETRONIC amps and 3 different speaker manufacturers.
Im pushing 1500 watts to 6 speakers and my buddies can hear the radio at highway speeds.
Old Jul 29, 2025 | 07:40 AM
Rob Harper's Avatar
Rob Harper
"Yes I could replace everything and probably be happy but as you can see I'm a cheapskate ( I bought a 2008, not a 2025)."
Don't feel bad, I bought a 2025 and I bet the stereo is worse than yours. They really cheaped out on the new models sound system. Oh, and at 500 miles it sprung an oil leak from the transmission main shaft, and I can't get the bike in for warranty repair until August 13 at the earliest. Until then, I'm riding my old trusty 2001 Road King. Anyway, check the stereo sub-forum. This forum is for the LiveWire HD electric motorcycles.
Old Jul 30, 2025 | 12:57 PM
Robertbc3141
Thanks to who move this to the proper forum, I don't know what I'm doing.
So someone mentioned there is a piggyback amp that attaches to the standard low end Harley Davidson stereo/CD player.
Is that the Rockford Fosgate 200W one?
Please assume I know nothing of stereo equipment.
Old Aug 8, 2025 | 09:43 PM
Robertbc3141
Default Do I need size adapters for the rear speakers of an Electra Glide speaker upgrade?
So I got 4 Rockford Fosgate 4 ohm R16 5x3 speakers - a marginal improvements over the stock speakers I'm told.
And 2 adapters for referring speakers that go from 5 and 1/4 to 6 and 1/2.
I was just going to start with speakers before I go down the rabbit hole money pit of amps and a new stereo.
The question here is do I need those adapters for the rear two speakers also?
Old Aug 9, 2025 | 09:19 AM
Buelligan666's Avatar
Buelligan666
5x3?
That would be an oval speaker. If you're talking about putting them in the Tour Pak pods, that's a no go. The pods have round holes for 5 1/4" speakers.
The factory speakers were 2 ohm. If you put 4 ohm speakers on a 2 ohm stereo you effectively cut your wattage in half. So if you were getting 25 watts @ 2 ohm, you're going to get 12.5 watts at 4 ohm.
You should cease spending money till you have a plan. You're just going to throw good money after bad.
Old Aug 9, 2025 | 09:42 AM
Robertbc3141
Originally Posted by Buelligan666
5x3?
Yeah I thought 5x3 sounded oval too but they're not.
Its just part of the Rockford fosgate model number.
I have them they're six and a half inch round diameter and I bought the adapters to go from 5 and a quarter.
And I believe you're incorrect about the ohms.
Old Aug 9, 2025 | 10:12 AM
itsmf's Avatar
itsmf
Get a plug and play sattelite radio!
Old Aug 9, 2025 | 10:19 AM
Buelligan666
I have a degree in electronic engineering. I built car audio as a hobby in high school and tech school. Electrician of 24 years. I teach 4th year apprentice class. I know exactly how ohms and amplifies work. Do a Google search...
