Primary chain adjusting
Old Sep 15, 2025 | 12:17 PM
Toneloco's Avatar
Toneloco
Default Primary chain adjusting
Would the primary chain out of adjustment cuase engine vibration at alil above idle then fades away just past that spot. front mount was changed but which is the one most considered thanks in advance
Old Sep 15, 2025 | 01:00 PM
Notgrownup's Avatar
Notgrownup
Doubt it
Old Sep 15, 2025 | 01:10 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
On some sort of motorcycle?
Old Sep 15, 2025 | 02:55 PM
Screamin beagle's Avatar
Screamin beagle
Its probably the front mount. I replaced a factory worn out one with a drag one and its been a vibration battle since. Ive retorqued it a dozen times at different settings using different installation methods and still i have off idle vibration and 5th gear right in the cruising range it feels like the frame is broken...lol...its not. Im waiting for what seems like the last factory one in the country to come into a dealership that i dont usually go to because of distance but they showed one in-stock but at another of their stores so im waiting. Researching engine mounts is similar to oil, shocks and tires...opinions are all over the place. I wanted stock because that bike was smooth as silk before the mount went bad. Good luck
Old Sep 15, 2025 | 07:56 PM
internet troll's Avatar
internet troll
What year and model? Some of them just shake like that. My 05 Electraglide would vibrate so bad at idle I couldnt read the gauges. I installed a new mount, I repaired the fairing (inner brace), could never get rid of it.........but it went away as soon as you came off idle so I just learned to accept it.
cushman
Jul 15, 2025 10:10 AM
sgw1064
Jan 8, 2023 09:19 PM
azharleyrider86401
Apr 8, 2011 05:43 PM
robster
Aug 5, 2008 09:34 AM
jlphillips
Apr 30, 2008 05:58 PM
