Squeaking noise
Old Sep 27, 2025 | 08:33 PM
jcwrench's Avatar
jcwrench
3rd Gear
Originally Posted by Sevenznuf
Thanks for the replies guys, will try to find the noise. Didn’t think about the drive belt, definitely will check tension on that!!
I had the same issue on my 07 Ultra Classic. Got the tension tool and adjusted the drive belt. It stopped.
Old Sep 28, 2025 | 06:28 PM
big cahuna's Avatar
big cahuna
Well being the owner of a almost 25 year old motorcycle, strange noises are something you can count on. I've had my share of "what the hell is that sound" moments. Well its not unusual that the engine gets a little clicky and ticky as it gets older. Sometimes just a oil change can make it not as noticeable. What I do every so often is get something to sit on, and a handful of different size wrenches. The I begin to check every nut , bolt and screw on the bike. Start with the front end, and work my way back. If you can see it, check to see if it's tight. Don't forget to check the return spring on the side stand. Pound lightly on the exhaust pipes, to see if the chrome covers are still tight, and the muffler clamps are still clamping. The rubber hanger bushings will squeak when they get dried out, and are cheap and easy to replace. I believe your shifter shaft has a grease fitting in it, as well as the brake pedal, give them a squirt to keep them quiet. And if you have a gremlin bell, take that thing off . You don't need an intensional noise maker. I would spend some time with a wrench in hand looking for loose stuff, before I start tearing things apart. Good luck.,,
Old Sep 28, 2025 | 06:53 PM
Ed Ramberger's Avatar
Ed Ramberger
I got under there and got the rest of the soft part of the belt guard off, it was laying up on the belt. Haven’t been able to ride it, raining a lot here! Are these motors known for having a “slight” lifter ticking noise? Like a loose rocker arm sound? That’s one of the noises when I’m riding it sounds like! Thanks for all the replies, I really appreciate it!
2200-2500 rpm is a very common rpm to get ticking that is considered normal snd not to worry.
Old Sep 28, 2025 | 07:38 PM
jcwrench's Avatar
jcwrench
3rd Gear
Originally Posted by big cahuna
And if you have a gremlin bell, take that thing off .,
Between the V&H exhaust and the stereo, only folks that hear my gremlin bell are the gremlins!
Zepxl1200
Apr 21, 2022 04:10 PM
dustydog2
Jun 27, 2014 02:06 AM
rockajet1
Apr 20, 2013 10:29 AM
E ticket
Aug 28, 2008 08:17 PM
05HARLEYMAN
Sep 29, 2006 06:22 PM
