Tire pressure
Old Dec 3, 2025 | 02:19 PM
Lindyk66's Avatar
Lindyk66
Default Tire pressure
My other changed the wheels on his Road Glide. Now he can’t get any indication of tire pressure.
Old Dec 3, 2025 | 02:24 PM
Goose_NC's Avatar
Goose_NC
Did he move the TPMS valve stems to the new wheels?
Old Dec 3, 2025 | 02:26 PM
Lindyk66's Avatar
Lindyk66
No, just finding out he needs to do this at a cost of $200. Is there any way around it?
Old Dec 3, 2025 | 02:28 PM
Goose_NC's Avatar
Goose_NC
Are the valve stems in the new rims Harley TPMS stems? If yes, the dealer may be able reprogram to see those.
Old Dec 3, 2025 | 02:29 PM
BigFuji's Avatar
BigFuji
Why didn't the place that changed the wheel move the TPS tothe new wheels?
Old Dec 3, 2025 | 02:30 PM
Lindyk66's Avatar
Lindyk66
He says old stems are Harley. But he called Harley dealer and they were the ones who wanted $200.
Old Dec 3, 2025 | 04:10 PM
Lindyk66's Avatar
Lindyk66
cause he did it himself
Old Dec 3, 2025 | 04:13 PM
Lindyk66's Avatar
Lindyk66
is it possible to do it yourself?
Old Dec 3, 2025 | 05:43 PM
NorthWestern's Avatar
NorthWestern
Sure, as long as there is no tire mounted to the wheel. Just mount the old sensor/stem in the new wheel after you remove it from the old wheel.
Old Dec 4, 2025 | 05:24 AM
jake24lt's Avatar
jake24lt
You also need the ID numbers off the sensors if using new. Those need to be programmed into the bikes bcm. If using the old ones, on the new wheels, make sure they go in the same orientation. IE, front wheel sensor goes in front, same with rear. if you swap them, the reading will be backasswards, as Harley doesn't have a pick up that senses the wheel like a car, as you cant rotate motorcycle tires.
