Electrical wiring question
Old Jan 11, 2026 | 02:34 PM
CrankyThunder's Avatar
CrankyThunder
Default Electrical wiring question
2016 Street Glide Special
Under the seat there is a set of three wires not connected to anything labeled "ACC-2"
Under the protective insulation they are Red, Black, and a Light Blue with a Dark Blue Line. They look to be about 12 gauge or 14 gauge. I have the service manual and cannot find any reference to them.
Is this an Accessory Hookup?
Is it switched with the ignition?
I assume it is fused, does anybody know the amps? Looks like 12 gauge or 14 gauge wires.
Are they wired to the switches on the dash?
I would like to use this as a power source for a Saddlemen seat heater if it is switched to the ignition so I do not kill the battery by wiring it directly to the battery. Saddlemen Seat Heater uses 2.2 amps on high.
Good Idea or should I simply wire it direct to the battery?
Thank you in advance.
Regards,
Crankster
Old Jan 11, 2026 | 04:10 PM
HeritageBrads's Avatar
HeritageBrads
Suspect it’s a switch operated accessory power outlet
Is there an acc switch on that glide ? Try powering it up.
Old Jan 11, 2026 | 04:58 PM
GalvTexGuy's Avatar
GalvTexGuy
I’ve never seen an ACC-2 label on any set of wires. The P&A Accessory Connector (Switched Power) is a 4-pin Deutsch connector under the left side cover.
Old Jan 12, 2026 | 07:11 AM
Dilligaffer's Avatar
Dilligaffer
Picture(s) may help.
Old Jan 14, 2026 | 10:35 AM
hattitude's Avatar
hattitude
Regards,
Crankster
Usually those connectors aren't labelled from the factory.
I suspect someone has added a "Switched Circuit Adapter Harness" (like the one pictured below) to your bike and labelled it themselves. It allows for a second switched circuit.
Most Accessory circuits are 15 or 20 amps. You can check your year/model wiring in the Harley Service Information Portal (SIP) or other manuals to see your specific Amp capacity.
You should also look to see what (if anything) is connected to the other connector. That would verify it's an add-on accessory connector, as well as checking for switched power as suggested in a post above.
If it is in fact an add-on to the accessory circuit, and nothing else with major power draw is connected to it, you will be fine....
Old Jan 14, 2026 | 11:58 AM
MotoJockey's Avatar
MotoJockey
See my reply to your question here.......
https://www.hdforums.com/forum/gener...at-heater.html
rblahetka
Audio Systems
Feb 14, 2022 07:24 PM
800screws
EVO
Jun 28, 2021 07:44 AM
Hoyt 1911A1
Audio Systems
Apr 1, 2021 09:29 AM
laythss
Oct 20, 2010 11:05 AM
jbaumann
Apr 16, 2009 05:03 PM
