Volt gauge reading 10 volts
Old Jun 22, 2021 | 10:36 AM
800screws's Avatar
800screws
Default Volt gauge reading 10 volts
I have a 89 fltc. Just installed progressive cartridges in the forks getting rid of that air tube and the ground block. I took all
the black wires and split them to two separate grounds to the triple clamp and ran a new ground to the engine. Since doing this my volt gauge now shows 10 volts and goes up to about 12 when running. I’ve taken the grounds on and off trying to find a draw but nothing changes. The voltage at the battery is about 12.6 and goes to 13 when running. When I use a jump box song with the battery the gauge goes to 13. Any ideas of what could be going on? It was working correctly before the fork mod.
Old Jun 22, 2021 | 10:59 AM
t150vej's Avatar
t150vej
I've seen that before. It was one of the harness grounds that connected to the ground block. But you've removed that so I can't pinpoint your problem, but am 99% certain you've missed a ground wire. Also check behind the headlight bucket on the fairing. That's where some of the wires from the (now missing) block terminate.
Why or wherever, you're missing a harness ground.
Old Jun 22, 2021 | 12:26 PM
800screws's Avatar
800screws
Alright. I dig in some more
Old Jun 23, 2021 | 07:47 AM
800screws's Avatar
800screws
Well. I went to the gauge itself. I’m getting only 10.6 on the orange wire with the other prong straight to the engine ground. So the gauge is working. I have 12.6 at the battery with the bike off.
Old Jun 23, 2021 | 09:03 AM
t150vej's Avatar
t150vej
Rats, I just deleted 3 nice paragraphs trying to do a correction. I'm pushed for time this morning so here's the abbreviated version; are the headlights brights? If yes, do the turn signals work? If no, check voltage at the ACC breaker on both sides. It's the one on the far left and has power in any switch position other than off or lock.
Other than lights, head and turn, there are 2 wires with power than go to the fairing - Acc switched, and 1 constant for the clock and radio. If the turn signals work the acc is getting good voltage but maybe not getting thru the forward harness.
Disconnect at the lower right of the fairing, find and check there for volts on the 2 hot wires. Again, if there's a deficient ground to the fairing gauges, they can feed thru themselves or their respective sender causing a parasitic effect on the other fairing gauge voltage. Like a short, but not a dead one. And the volt gauge is literally at the very end of the Acc circuit.
Like I said, I've seen this a number of times over the years, gauge shows 10.6 and it's always been a ground issue. Just depends on what else isn't acting right as to where it might be and where to look. Got to run.. good luck.
Old Jun 23, 2021 | 11:36 AM
800screws's Avatar
800screws
Got your message. The gauge is reading correctly.
ill go trouble shoot with your info. Ty
Old Jun 23, 2021 | 05:48 PM
800screws's Avatar
800screws
I don’t know what I did but I’m reading 11.2 at the wire going to the gauge with the switch on but bike not running. Gauge is still showing 10. Must be a bad gauge
Old Jun 23, 2021 | 06:00 PM
WP50's Avatar
WP50
The oem gauges are considered a guestament by me. Lots of things can affect a 1 v reading difference.
I just learned to make it work in my head but double ck with a good dvom
WP
Old Jun 28, 2021 | 07:27 AM
Wardfan220's Avatar
Wardfan220
WP
My 97 Ultra always shows 10v when not running, new battery, no wires messed with. I think it may be "normal"
Old Jun 28, 2021 | 07:44 AM
EVOrider's Avatar
EVOrider
Those gauges are not accurate….but show just enough if you have an electronic issue.
Sounds like a bad ground or a wire has an issue.
hyprr1
Oct 28, 2019 10:43 AM
Cozz
Jun 25, 2019 04:43 PM
littled62
Dec 10, 2012 09:19 PM
Taylorized
Aug 14, 2008 09:42 PM
Steve On 3
Dec 14, 2007 11:20 AM
