07 SG headlight
Old Sep 10, 2007 | 11:35 AM
mikes300's Avatar
mikes300
Default RE: 07 SG headlight
I installed the sylvania silver star bulb in mine, big improvement got it at the auto parts store for about 20 bucks.
Mike
Old Sep 10, 2007 | 01:33 PM
reno572's Avatar
reno572
ORIGINAL: drdiesel1
That`s because the headlamp is aimed down to far.
I adjusted both my 07 SG and 08 FLHTCU to a proper level and now I can run at night with my shades on and still see.
Aftermarket bulbs are also a good idea, but try the proper adjustmentbefore you buy the $30.00 white bulb.[8D]
Thats what I was thinking, my low beam was terrible, I switched to a silverstar bulb and adjusted it correctly per the manual. It was 5 inches too low. I couldn't believe the difference after I adjusted it.
Old Sep 10, 2007 | 04:10 PM
iclick's Avatar
iclick
ORIGINAL: timidones
Last nite while riding with a group, someone asked if my headlight was on. Now i have always thought the low beam was kinda crappy, high beam is fine. Is it just me? or are these kinda lousy low beams, I'm gonna switch it over to a whiter blub, some of the post i have seen, Thanks
Buy the 90/100w H4 replacement bulb from Kuryakyn for $9 (#2137):
http://www.kuryakyn.com/products.asp...ey&ci=2579
Old Sep 10, 2007 | 04:29 PM
MNPGRider's Avatar
MNPGRider
Thanks for the link, iclick. They are cheaper than jc whitney, who also nicks you pretty bad for shipping.
Anyone try the 2142 or 2144 Blue/white bulbs?
I live in a high deer kill zone. I set my spots to shine slightly to left and right, and slightly down on the left side, rather than straight ahead. Thatreally made a difference as far as lighting up the ditches. Down on the left side to not blind oncoming traffic.
Also, on this site under "Electrical and Lighting," is the schematic for wiring them to be on all the time, whether or not you are on low or high beam.
Old Sep 10, 2007 | 04:41 PM
kart11's Avatar
kart11
Can someone tell me what the recomended adjustment should be for low beam ? I can use my garage door if someone can give me some ref. points to go from.
TIA
Old Sep 10, 2007 | 04:52 PM
MNPGRider's Avatar
MNPGRider
Headlights are usually set via high beam, but with the myriad of bikes out there that may vary.
To set your light using high beam, have the bike level, with the normal weight of one or two passengers on it, depending on which way you ride the most. I split the difference, which works well.
Measure 25' from the contact patch of the front tire, to a vertical wall. Draw a horizontal line on the wall exactly the same height above the floor as the center of the headlight.With bike upright and perfectly aligned, the center of your high beam should be centered on the line.
Take a screwdriver with, find a county road with no traffic and a center stripe. Drive right down the center, and align the low beam left/right with the center stripe.
That's about as good as it's gonna get! Note my post about spots. A little bit of deflection right or left makes a tremendous difference in lighting up the ditches!
Finding a white commecial garage door with a level parking lot is the perfect place to align lights, as most home garages are shorter than 25 feet and driveways are seldom level.
Old Sep 10, 2007 | 05:07 PM
MNPGRider's Avatar
MNPGRider
BTW, I've also found that just changing bulbs will through off the alignment slightly, as each manufacturers bulbs may be made slightly different.
6 gun
Apr 25, 2018 05:41 AM
Reno007
Electrical/Lighting/Alarm
Apr 19, 2017 10:47 AM
Elqueso2
Apr 10, 2013 12:40 PM
MichiganDave
Jul 25, 2012 09:01 PM
CSI
Sep 14, 2006 11:32 PM
