Back pressure.
Old Feb 18, 2026 | 08:34 AM
hattitude's Avatar
hattitude
Originally Posted by Rains2much
I have been doing this for over 30 years.
Someone suggested that trick for my straight pipes back in '83ish on my shovelhead.
I thought he was a loon.....
Didn't learn he was smarter than me for some years....
Old Feb 18, 2026 | 09:04 AM
Rains2much's Avatar
Rains2much
It’s the reason the uneducated uninformed people say open or drag pipes run poorly on the street. A properly tuned (length diameter) drag pipe with something to counter reversion is an excellent pipe for a Harley street bike.
I roll my eyes with the negative Nancy’s that run there mouth saying they tried drag pipes and they suck (like you S&S video… guys a moron) you can’t stick some stupid chopper craze 20” long cut off drag pipes on a bike and make it run.. so then you assume all drag pipes are bad and walk out with the S&S clown and throw them in the dumpster so you can sell your dumb one size only fits one size 2 into 1 pipe.
Generally the right drag pipe on the street for an 80 to 88” motor will be a 1 3/4 diameter 32 to 40 inch long set of equal length pipes. A high compression 96-113 is on the fence with 1 3/4 to 2 inch diameter and over 113 inch motors NEED a 2 inch diameter pipe. I’ve even seen high compression 98 inch shovels benefit from 2 inch diameter pipes before.
Old Feb 18, 2026 | 09:20 AM
Randystreetglide's Avatar
Randystreetglide
6th Gear
I’ve done something similar with a washer. Guess I’ll give this one a try. Thank you
Old Feb 18, 2026 | 09:28 AM
Rains2much's Avatar
Rains2much
The best is probably the DK Customs Thunder torque inserts. I doubt my thumb screw vs a welded washer is any difference. In fact a straight bolt through helps. Hot Bike did this massive exhaust pipe shoot out back in the day and consistently minimized the dip on all drag pipes tested just but holding a pencil at the end of the pipe during the dyno pull.
Old Feb 18, 2026 | 09:49 AM
Beartooth Rider's Avatar
Beartooth Rider
Does anyone remember these?
The 305.4 cc (18.64 cu in) overhead cam engine had a redline of 9000 rpm and contrasted sharply from the low-revving European and American bikes of the day. Running straight pipes with small internal baffles, CL77s featured a loud and very distinct sound from the 180 degree firing order of this parallel twin. Many of these motorcycles featured aftermarket snuff-or-nots (commonly misspoken as "snuffer nuts"), which featured a flat washer like piece of metal which pivoted just inside the tips of the exhaust pipes to quiet or increase the sound of the exhaust at any time during operation simply by twisting the external ****.
In later years Honda joined the end of the exhaust pipes with an external factory installed muffler to control exhaust noise. At first it was slipped on and clamped. Later models came with only one of the twin side pipes welded onto the slip-on muffler. The last version came with both pipes welded to the slip-on muffler.
Image and text from Wikipedia.
They really did sound great!
Old Feb 18, 2026 | 10:18 AM
Rains2much's Avatar
Rains2much
Growing up that was my best friends starter bike. He still has it to this day.
Old Feb 18, 2026 | 10:34 AM
Beartooth Rider
They were very popular!
Back on topic, the reversion problem with open exhaust gets conflated with back pressure.
Back pressure does mitigate reversion, but there will still be a loss of torque at lower RPM.
Regarding the need for a tuner, intuitively we should all want to run the correct Air/Fuel Ratio and Ignition Timing in our builds.
Old Feb 18, 2026 | 10:43 AM
Rains2much's Avatar
Rains2much
…. Or set timing by mph through the traps.. and a altoid can of jets.
No 3 week waiting list, load on a truck, drive an hour, wait.. pay $350-$550.. load, drive home and then be held hostage if you wanna try different pipes or a cam.. just throwing it out there.
Old Feb 18, 2026 | 11:43 AM
Beartooth Rider
I learned everything I know about EFI (not much), street tuning my 2010 Ultra Limited.
These days I have a Master Tech that has earned my complete confidence, and I just rely on him.
Old Feb 18, 2026 | 04:21 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Yep I started with a 2010 Ultra Classic and the original unlocked Super Tuner. Built a basic tune that ran decent, then got a V&H FP3 because I wanted to calibrate the speedo and used that SE tune as a base for the FP3 to auto tune. That cleaned it up even more. I was impressed with the user friendliness of that FP3. Really seemed like a do it yourself basic tune. Don't know if such critters exist for the M8s or not.
