Don't most, or all automatic clutches for Harleys require MANUAL release for shifting, that they are only "automatic" for starting from a stand-still? Is there such a thing as a clutch that will engage smoothly (like a centrifugal clutch) but will only drive in one direction (like being connected to the transmission input shaft through a ratchet or sprag clutch) that will disengage from the input shaft when the throttle is reduced or closed for shifting?
I have no personal experience with this company, but EFM modifies stock clutches to make them fully automatic. Russell of Exile Cycles runs these. https://efm-auto-clutch.square.site/
I am a threw the knee amp. No knee, which makes it much harder to shift. If you are below the knee i think a longer shift peg on the shifter may work ok for you.
What i did was to rotate the rear shifter arm straight up and weld a rod onto it with a shift ball. I just reach over and shift with my right hand. And yes, i have to take my hand off of the throttle to do it. It's slow ,but i am still riding .
I do ride a trike now. If below the knee amp riding a 2 wheeler is still possible.
Many different ways to shift the bike . I didn't care for the electric shifters, i wanted to shift it myself. Let us know what you decide on. Good Luck !
I thought about using the Widow maker shifter and bending it up straighter and leaving my clutch on the handlebar. Don't care for the clutch on the shifter.
I did a work up of something similar when i had a broken knee cap.
I have seen a solenoid system connected to the gear change linkage with buttons on the handlebars for up and down gear shift. No need to take hands off the bars to operate the bike as you would with a jockey change.
I have seen a guy quite regularly who has a prosthetic leg. He put a U shaped tray on his bike for that foot and basically rides one legged. I don't know what he does for gear change though but it isn't a jockey shift.
All I can add is I worked with a guy, left leg amputated below the knee and prosthetic leg. Had a Road King and he rode A LOT. He had some sort of push button pneumatic shifter. Worked great for him
