Getting to the stator
Old Mar 21, 2026 | 06:19 PM
Cheyennetrk's Avatar
Cheyennetrk
Default Getting to the stator
2018 Ultra Limited. Ok, primary is off, bought the right sockets and the torx, even bought the chain block. For the life of me I cannot break loose the 1-3/4" nut on the compensator. Or the torx bolt. Is there a trick to this? I've even tried a low power battery operated impact but I'm having no luck getting either one broke loose.
Old Mar 21, 2026 | 06:31 PM
GalvTexGuy's Avatar
GalvTexGuy
I had to use a 1/2” drive 24” breaker bar.
Old Mar 21, 2026 | 06:57 PM
Max Headflow's Avatar
Max Headflow
First off, toss the block. Second, use the 1 3/4 nut to hold the crank. Third use the T70 to back off the bolt. Use a cheater if you ain't got enough torque.
Old Mar 21, 2026 | 07:23 PM
hardheaded's Avatar
hardheaded
Heat is your friend here. Heat the comp.. bolt up and it will come loose. Softens the locktite.
Old Mar 21, 2026 | 07:48 PM
Cheyennetrk
Got that too, was the first thing I tried. Damn thing won't budge
Old Mar 21, 2026 | 07:50 PM
Cheyennetrk
Ok, so don't try to remove the nut first? Just use a wrench on the nut to hold the assembly still?
Old Mar 21, 2026 | 07:52 PM
Cheyennetrk
A bit concerned with using a torch there, oil and flames don't usually mix all that well. Besides, wouldn't that damage something in the compensator? I've never done this before, vids made it look pretty simple. But I did notice there are what look like rather large washers behind it, don't really want to warp them.
Old Mar 21, 2026 | 08:01 PM
Max Headflow
The nut is connected directly to the crank through splines. No threads.. Buy the manual.. You can use a jam bar to lock up but done use a jam block. One thing you'd do is damage the primary chain tensioner if not removed.
Old Mar 21, 2026 | 08:13 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Just wait until you have to torque it back down!
Old Mar 21, 2026 | 08:17 PM
Lonewolf176's Avatar
Lonewolf176
This and get a longer bar.
