New Ohlins 779
Old Apr 4, 2026 | 06:40 PM
07ntrain's Avatar
07ntrain
Default New Ohlins 779
Just ordered new ohlins 779 shocks and had a quick question for those who installed them. I jad watched a video on the set up and it said that if I do the spring calculator then that should eliminate the need to do the sag measurements and just do the compression and rebound. Im not sure thats correct but I dont have the shocks yet so have some research time.
Old Apr 5, 2026 | 04:21 PM
buell95's Avatar
buell95
You need to set the sag.
Old Apr 8, 2026 | 04:24 AM
Jshopes's Avatar
Jshopes
in theory it should eliminate the need to not do it, but i double checked mine when i put them on.
Old Apr 8, 2026 | 06:29 AM
RKZen's Avatar
RKZen
Why not give Ohlins a call to confirm? They have a USA HQ a couple hours ride from me in NC. Their # is at the bottom of their web site.
Old Apr 9, 2026 | 07:02 PM
07ntrain's Avatar
07ntrain
Im currently at work in the middle of the ocean with no service. I did email them last week but no reply yet.
Old Apr 10, 2026 | 12:31 PM
Jshopes's Avatar
Jshopes
I screwed that up and cant edit. If you set the preload at what they recommend it will set the sag pretty close to where they recommend it to be. I would put them on and double check it to see where it falls, but its going to be close if you put your correct weights in.
jarrydj
Mar 25, 2025 08:25 PM
Mchad
Aug 13, 2021 09:06 PM
Kuz
Mar 3, 2013 02:37 PM
rizzle
Feb 25, 2013 05:43 AM
JRK5892
May 26, 2009 12:56 PM
