New rear suspension question
Old Mar 7, 2025 | 12:22 PM
jarrydj's Avatar
jarrydj
1st Gear
Default New rear suspension question
Just got Pro Action rear suspension for my 2016 FLHTK. Purchased them through DK. Gave all my info about my weight and how often I ride 2up and so forth. I got the shocks yesterday afternoon and had them installed last night. I watched all the videos posted by PA and tried the shocks out just as they came first. The initial ride was not good so I came back and checked the bumpers. The shocks were bottoming out. I did a couple turns on the springs and reset the bumpers. Test rode again and still the same feeling and result. After a couple more rides, I ended up having to tighten the shocks a total of 8 full rotations from out of the box. I am also 3 clicks out on the dampening. The shocks are finally not bottoming out anymore by they don't quite feel as smooth as I thought they would. I'm 225lbs and springs that came on there have 3 little blue marks on them. I plan on calling PA on Monday but I wanted to see if anyone on here had any input as to what I could possible do differently. I was surprised that it took that many turns on the springs from what they sent me.
Old Mar 7, 2025 | 12:59 PM
hattitude's Avatar
hattitude
The info they collect, I assume is for what springs to include with the shocks.. I suspect you need to dial in the pre-load yourself...
The 8 full rotations...do you know the total number of rotations? Where would that "8 rotations" be in respect to the total preload scale?.... max, minimum, middle?
Same question on the damping, where is the the "3 clicks out" along the entire damping scale?
Did you take any sag measurements?
How many inches of travel do those shocks have total?
We would need that info to know if the shocks are set up properly...
Old Mar 7, 2025 | 01:58 PM
Oko's Avatar
Oko
Calling Pro Action will straighten you out. I have the same bike. But I went with 11" to lower the bike. I also did their front fork springs.
The 11" are not plush. Neither are the fronts. If you're close to western Pennsylvania, you can ride over, (with an appointment), and get it set up correctly.
That's what I did.
Old Mar 8, 2025 | 06:38 AM
Notgrownup's Avatar
Notgrownup
On my trike I made some wholesale changes after calling George at PA , he gave me a measurement of what he thought the lenght should be from the adjustment ring to the end of the spring and it was 7.5” . With 2 clicks in on my adjuster screw. The bike rides completely different now. Way better than before.
Old Mar 8, 2025 | 08:44 AM
big-C's Avatar
big-C
Call Pro Action and talk to George. You'll be glad you did.
Old Mar 10, 2025 | 09:22 AM
pyuchem's Avatar
pyuchem
I had similar issues with PA. Tried everything George told me and Harley technician to do. Still didn't perform the way I expected. Sent them back and got RwD. They turned out to be 100 times better than PA for me.
In my case I’m light weight at 130 lbs. not a typical beer weight HD rider lol.
I know this doesn’t help, just sharing my experience. Hopefully a call to George will sort things for you. GL.
Old Mar 10, 2025 | 10:09 AM
jarrydj's Avatar
jarrydj
1st Gear
Called PA this morning and DJ gave me some adjustments to try. I just did them in my parking lot at work and will ride after work to see how it turns out. He said that I may need heavier springs if it doesn't work out.
Old Mar 11, 2025 | 06:13 PM
StoneTrekker's Avatar
StoneTrekker
I've been a Pro Action advocate for years. I can't really fault their products in any way. Nevertheless, I've (we've) never consistently been able to find true comfort on the shocks. I'm sure it's either a setting or spring issue, but I haven't been able to sort it out. I've called and talked to DJ at least 3 times and done exactly what he suggested. Still, the harder bumps are disturbingly sharp and very uncomfortable. I probably should call them (again) but I feel like we've tried everything possible short of actual spring change. And the little foam slider/bumpers are of no help as they quit working within a year. They are loose and cannot be positioned on the main shaft.
I've got my eye on something totally different now.
Old Mar 11, 2025 | 06:22 PM
buell95's Avatar
buell95
Are you talking about the rubber bump stops on the shock shaft? If your trying to use them to measure and they don't stay in place.
Tie a small zip tie to the shaft and cut off the excess and use the zip tie to measure.
Old Mar 11, 2025 | 07:37 PM
StoneTrekker
Yes....nice idea there.
