New rear suspension question
Old Mar 12, 2025 | 12:14 PM
jarrydj's Avatar
jarrydj
1st Gear
Originally Posted by StoneTrekker
I've been a Pro Action advocate for years. I can't really fault their products in any way. Nevertheless, I've (we've) never consistently been able to find true comfort on the shocks. I'm sure it's either a setting or spring issue, but I haven't been able to sort it out. I've called and talked to DJ at least 3 times and done exactly what he suggested. Still, the harder bumps are disturbingly sharp and very uncomfortable. I probably should call them (again) but I feel like we've tried everything possible short of actual spring change. And the little foam slider/bumpers are of no help as they quit working within a year. They are loose and cannot be positioned on the main shaft.
I've got my eye on something totally different now.
Oh man, that sucks to hear. I am hoping the new spring and some tweaks will help. They have been great with customer service so far. I also wonder if I am expecting too much out of an after market suspension.
Old Mar 12, 2025 | 12:32 PM
Notgrownup's Avatar
Notgrownup
I use the Zipties.
Old Mar 24, 2025 | 01:59 PM
GSQ3's Avatar
GSQ3
You should try the different springs. I bet that's what it is.
Old Mar 24, 2025 | 03:01 PM
StoneTrekker's Avatar
StoneTrekker
UPDATE: I have spoken with DJ at Pro Action Suspension a couple times. I carefully described everything about our bike, current shock settings and what it's doing during the ride. Suffice to say he gave me a significant bunch of data and got me to a starting point. Thus far...after several additional adjustments...the shocks still seem to bottom, even with strong spring preload for our combined weight. Something is not quite right, and DJ asked me to bring the bike back for shock evaluation and potential rebuild. Could be springs...could be internals. After an upcoming trip to NC, we plan to ride to P A and let them get to the bottom of this....no pun intended.
To be clear, I have absolute faith in PAS and DJ. Their products are excellent and I'm a believer. I'm sure they'll iron out my shock issue.
Old Mar 24, 2025 | 07:30 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Very small incremental adjustments.
We have really enjoyed our PA Suspension front and rear. I’ve ran it now on 4 bikes, over 9 years and 100k+ miles.
I knew I needed a slight adjustment on the rears on the 22 RG. We were lucky to run into DJ from PA in Daytona and when I told him what I was feeling, he immediately said to add ONE turn of preload.
We got back home and as I was cleaning the bike I made the change. We rode 200 miles Saturday and I had not said a thing to the Carolina Girl. She knows suspension! We stopped for fuel 30 miles in and she asked what I did to the suspension. I asked if it was good or bad, she replied PERFECT!
George and DJ are experts. Call and talk with them. Always make very small adjustments. It does not take much.
Old Mar 24, 2025 | 07:31 PM
Black Ultra's Avatar
Black Ultra
I have the PA shocks on my FLHTK as well. At first I thought the bump stops were too loose to set and gauge bottom out. I was going to try the zip ties. Then I found out there is an O ring below them that needs to be moved up with the stop to hold them in place on the shock shaft. It's really hard to see, but once you find it, a small pick makes fishing it up much easier. No need for zip ties for mine.
Old Mar 25, 2025 | 02:13 PM
jarrydj's Avatar
jarrydj
1st Gear
Got a heavier spring from DJ and that was the key to what I was looking for. I agree totally with the small adjustments with the dampening. It is a big improvement over stock, especially riding 2-up. I look forward to getting the front suspension done to compliment the rear.
Old Mar 25, 2025 | 06:39 PM
Rob175's Avatar
Rob175
jarrydj .... THANKS for the "follow-ups",,,,,I read lots of posts here and I'm always disappointed when a thread starter doesn't follow up with the solution they found..... it helps ALL of us.
Old Mar 25, 2025 | 08:25 PM
Notgrownup's Avatar
Notgrownup
Look into the Intiminators from DK. I really like the improvements. Not harsh but no nosedive.
Pnut48
Oct 7, 2018 01:32 PM
WildBill2566
Jul 15, 2012 04:27 AM
swbob
Apr 24, 2012 04:13 PM
fixedmlc
Apr 21, 2009 07:38 AM
roadster rider
Oct 30, 2005 02:45 AM
