Rear Suspension Question....
Old Sep 24, 2018 | 09:29 PM
Pnut48's Avatar
Pnut48
Default Rear Suspension Question....
So after some riding on my 48, I've come to the conclusion that the rear suspension needs some help. These tore-up Mississippi roads aren't easy on the rear end. Now, I realize part of the point of the 48 is that the bike is low-slung, but I'm also about 220 lbs so I am assuming I can push the springs down a little even if I went with shocks with a slight lift. Not talking about 15" Burly's or anything.
From what I can tell, Progressive's are going to be the way to go if I don't want to get into $600 ish shocks, which I don't. So my question is, would 11" shocks still technically be better than the factory shocks, or should I push up to 12" or even 13"? Are Progressives good shocks to begin with? Should I look at a different brand? What if I ever want to set it up for a passenger? Who shot JFK? Did we really land on the moon? What is the meaning of life?
yeah I got a little off track there....
Thanks in advance for any help
Old Sep 24, 2018 | 09:35 PM
whylee's Avatar
whylee
I think you would be better served with 12 1/2 or 13 inch shocks. Progressives are better than stock and if you get the higher dollar progressives they are better yet.
Old Sep 24, 2018 | 09:58 PM
Norcalsvt's Avatar
Norcalsvt
I would go with the Twin adjustable biturbo's through DK Customs. Best bang for the buck.
Old Sep 25, 2018 | 05:26 AM
Steve Sportster's Avatar
Steve Sportster
I changed the rear shocks on my 2017 XL1200T Superlow to 12.5" Progressive 412s. I sometimes think I should have gone to 12" but I'm very happy with these. Very reasonable price, too. I also replaced my original front fork inners for Progressive Monotubes. Equally happy.
Old Sep 25, 2018 | 05:33 AM
grbrown's Avatar
grbrown
Two things affect ride qwuality with shocks - length of stroke and damper quality. So by all means use longer shocks, but also be sure to get shocks with better quality dampers. That usually involves spending a little more!
Old Sep 25, 2018 | 11:20 AM
mrhammer2u's Avatar
mrhammer2u
13" at minimum. I'm your weight and I blew a lot of time and money trying to stay low and cheap. For bigger people and rough roads LOTS or travel is king.
If you want to stay low just add a 1-2" lowering block.
Old Sep 25, 2018 | 12:48 PM
Mborras1's Avatar
Mborras1
Progressive 12.5 HD
Old Sep 25, 2018 | 02:54 PM
ChromeSporty's Avatar
ChromeSporty
When I got my 2006 XL1200C it was lowered and only had 1 inch rear suspension travel. It had a real tough ride. I put Progressive 412's 12.5 inch HD shocks and raised the bike considerably. I had to raise the front back to stock height as well. It now has a nice plush ride, even two up. I also noticed that the bike handled much better, especially in the corners.
Old Sep 25, 2018 | 06:15 PM
Imold's Avatar
Imold
I went cheap, a pair of used Road King airshocks, lighter oil (can't remember if I used 5 or 10 wt, think it was 5) and only 9 ounces of it. It takes a nearby road that would lift me off the seat on the frost heaves smoother than my van or pickup does. I was worried they might mess up the handling, but if anything, it feels better now, bike feels planted better not jolting on bumps in the curves.
Old Sep 25, 2018 | 08:41 PM
Pnut48's Avatar
Pnut48
thanks for the help guys, I think I will probably go with some 12.5" 412's and see how that works out
