View Poll Results: Axle Lube
Anti-seize
76.00%
Grease
24.00%
KY
0%
Nothing, nada, zilch…
0%
Voters: 50. You may not vote on this poll
Axle lube
Old Apr 23, 2026 | 01:12 PM
Funnel's Avatar
Funnel
Default Axle lube
Manual says a little anti sieze but some say grease, what say you?
Popular Reply
Apr 23, 2026, 01:16 PM
strokelessone's Avatar
strokelessone
Doesn't really matter. a good quality grease or Never Seize will work. I personally use Never Seize because I like finding it on everything I touch for months afterwards.
Old Apr 23, 2026 | 01:16 PM
strokelessone
Old Apr 23, 2026 | 01:47 PM
Rounders's Avatar
Rounders
Anti seize, I put that **** on everything
Old Apr 23, 2026 | 02:01 PM
scott_0's Avatar
scott_0
intended or not
Old Apr 23, 2026 | 02:05 PM
Taxgod4u's Avatar
Taxgod4u
Grease, as OZ never gave nothing to the Tin Man. Antiseize is highly contagious.
Old Apr 23, 2026 | 05:32 PM
Bullwinkle58's Avatar
Bullwinkle58
Grease. That's one of the things the manual says that I choose to do differently.
I believe the manual says anti-seize because (I think) it also says when you see grease on your axle, you know your bearing seal is gone & it's time to replace the bearings.
I believe that keeping the bearing seals greasy prolongs the life of the seals too...
Old Apr 23, 2026 | 06:30 PM
Ghetto blaster's Avatar
Ghetto blaster
Old Apr 23, 2026 | 11:09 PM
JimL_15 Electra Glide's Avatar
Anti-Sieze
Old Apr 24, 2026 | 03:25 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I have used the permatex silver that seems to get everywhere but the axles on my bikes show no signs of rust and come out very easy when I want them to.
It's also worth getting the internal spacer out and coating both sides of that.
Old Apr 24, 2026 | 05:18 AM
Jackie Paper's Avatar
Jackie Paper
You missed copper, aluminum, zinc, ceramic, or molybdenum based anti-seize and that's not all of them.
Might be a good idea to use what's best. For garage queens and sunny day cruises, doesn't matter..
As required now ...Caution AI
Anti-seize is a specialized compound designed to prevent static parts (like bolts) from fusing due to high heat, pressure, or corrosion, where as grease is a lubricant designed for moving parts to reduce friction.
Anti-seize uses solid metal particles (copper, nickel, aluminum, zinc) to protect, while grease uses oil and thickeners to lubricate.
Probably the best is a Marine Grade Anti-Seize due to moisture and road salt.
Propeller anti-seize. It's so sticky, it takes turpentine or lacquer thinner to get off your hands.
