2011 flhp rubber oil cooler lines
Old May 4, 2026 | 07:20 PM
98glider's Avatar
98glider
Default 2011 flhp rubber oil cooler lines
I was wondering the oil cooler lines by the regular mine are starting to dry out. I would like to replace both of them I noticed there’s a clamp up top that I can squeeze to get off but the other Ones that are lower are pressure fit it on. Can I just use a clamp. Also will there be a lot of oil coming out. I just changed the oil. Thanks
Old May 5, 2026 | 09:04 AM
hattitude's Avatar
hattitude
IMHO.... Yes, you can use a stainless worm drive clamp or fuel injection hose clamp, of the proper size.
FWIW.... The OEM clamps are "Oetiker clamps". They require a special tool to install, and can be frustrating to remove for those without any experience dealing with them, but they are superior to the other two style clamps. They are used several places on a Harley. I use them and prefer them to the other hose clamps.
I have removed those hoses a couple times, but I don't specifically remember the amount of oil that came out. IIRC, it's minimal, probably just what is in the hoses. That would be just enough to get messy.
Old May 5, 2026 | 10:22 AM
98glider's Avatar
98glider
Do I have to prime anything before I start the bike up.
Old May 5, 2026 | 10:44 AM
eighteight's Avatar
eighteight
^ No.
ATM983
Jul 20, 2016 08:25 AM
Old Cool
Jul 22, 2011 09:30 PM
iwillfixthem4u
May 16, 2011 12:41 AM
mgmmgm
Mar 7, 2011 07:18 PM
TCMAN
Nov 9, 2010 04:01 PM
