Meathooks
Old May 13, 2026 | 05:46 PM
2011BlackGlide's Avatar
2011BlackGlide
Default Meathooks
I plan to install 12” prewired meathook bars on my 2016 Ultra. Do I want to just delete the heated grips or how much of a hassle/expensive is it to reinstall them onto the new bars?
Old May 14, 2026 | 06:27 PM
Navy Mustang's Avatar
Navy Mustang
If you're reasonably handy you'll be just fine. Make sure you order the extensions for the extra height bars, if you need them. I installed the 14" meat hooks and required the extensions. You'll need to connect the end of your heated grips wires to the extensions...that requires pinning. Get the small tool and you'll be just fine making those connections. Last part is working the wires through thebars. Many ways are possible, so pick your poison. But I use dawn and water in a spray mist for lube. Good luck.
Old May 15, 2026 | 08:45 AM
Godzlla's Avatar
Godzlla
When I was getting the 135 installed on my '21 CVO UL, I had the dealership put 14" Factory 47 Assault bars (meathooks) on it. The cost was a few hundred if I recall and it did not require extensions on any of the wiring.
Old May 17, 2026 | 09:17 AM
Ultra103's Avatar
Ultra103
I put 14" meathooks on mine and had the extensions. I could have 'just' done it without them but the heated grip connection under the dash would have been pulling.
Hopefully the grip wiring is already installed and you can just splice the left side in. You have the smaller CAN-Bus plugs though so that makes pulling the main wires easier if you have to redo any.
hoggzzer
2014-2024 Touring Models
21
Sep 30, 2025 08:40 PM
mallora
Dec 19, 2021 06:58 PM
plongson
Jun 2, 2015 05:21 PM
BaggerJohn
May 17, 2012 06:51 AM
al baehr
Oct 20, 2009 01:32 PM
