Brake Pads
Old Sep 10, 2007 | 05:17 PM
trackadaptor's Avatar
trackadaptor
Default Brake Pads
Any good post and picturesfor removal / installof the Rear Brake Pads - without removing rear wheel..
Or is this impossible on a FLHX 2007 Street Glide ?
What size is the "Socket Torq" to remove the brake pad pin ?
Old Sep 10, 2007 | 05:57 PM
raporte's Avatar
raporte
Default RE: Brake Pads
I'd pony up the $60 for the service maual. It has all the info and more than you'll ever need. Plus it will warn you of things to be watchful for so you don't screw it up!!
Old Sep 10, 2007 | 06:08 PM
Mr Wonderful's Avatar
Mr Wonderful
Best money I ever spent for my bike was the 63 dollars for the Service Manual. Less than an hour's labor charge, and has saved me a ton of money.....and a lot of time hoping someone would take the time to try to explain a process on one of these forums.
You'll be surprised at the manual........excellent information, and yes, even pictures.
Old Sep 10, 2007 | 06:10 PM
trackadaptor
ORIGINAL: raporte
I have the Manual
Just lookingfor
Old Sep 10, 2007 | 06:12 PM
trackadaptor
Is it the: "......without removing rear wheel....." that your missing ?
Old Sep 10, 2007 | 06:14 PM
sewerat's Avatar
sewerat
1/4 12 pt and the other one you will need for the front is a 10mm 12pt
The easiest way is just pull the pin and then carefully wiggle twist a flattip screwdriver to loosen the pads off what you are in fact doing id pushing the pucks back in, (I'm gonna get flamed for telling you this method you know) then eventually they will just fall right out put the new ones in and replace the pins. Dont forget to use a slight bit os anti-sneeze
Old Sep 10, 2007 | 06:43 PM
trackadaptor
ORIGINAL: sewerat
Great Info. , will replace my pads tonight
newhogger
Apr 19, 2016 01:18 PM
Ironworker340
Nov 9, 2011 09:04 PM
Drumstyks
Oct 5, 2010 12:07 PM
PDDGM
May 31, 2008 10:56 AM
Beavis
May 23, 2006 12:05 AM
