Inner Primary Bearing.
Old Yesterday | 06:27 AM
kojak's Avatar
kojak
Originally Posted by Silent Glider
Hello Again.
Thank you for the many replies.!
I went to the shop, talked to the owner.
(this repair shop is a highly respected Harley repair in this area)
So I trust their advice.
The man said that if he could hold onto my bike for one or two weeks, he would get it back up on the lift and replace the bearings
(He said it could also be clutch bearing)
Estimated cost $600 to 800.
So I did agree.!!
My upcoming trip starts July 2.
So. I am excited that bike should be ready in time.
Thanks again for the replies.
I appreciate very much.
-SG.
This is no easy job. It involves removing the entire primary, starter motor, inner primary for starts. 4-6 hours of labor and specialty tools. Since they are going to have the primary tore apart, have them look at and upgrade other components i.e. compensator etc.
Old Yesterday | 06:37 AM
Rounders's Avatar
Rounders
Not sure I would do compensator. Id probably do tranny shifter shaft seal
When did Harley update the comp? I still riding the bad style on my 2007 with 80k. Though it's on my mind
Old Yesterday | 08:39 AM
hattitude's Avatar
hattitude
The first update was in 2006, ostensibly to handle the power for the pending switch to a 96" engine. They updated it again in 2007, then even again in 2010 (or 2011) when an SE comp version became OEM.
The 2010 version was less problematic than the '06 & '07 updates, but still had some oiling issues.
Finally, in 2014 with the Rushmore bikes, they updated to the best version of the Twin Cam compensators. It is the one easily identified by an oil scoop either built into the outer primary cover, or added to an earlier primary cover as a retrofit, to direct oil to the core of the comp.
It has been far less problematic than its predecessors. It is also the one now offered as the "Big Twin Screamin' Eagle Compensator" for retrofit to earlier Twin Cam engines back to 2006. There are two retrofit part numbers. One for years that need a new rotor for the upgrade (approx. '06-'10) and one for those that don't need a new rotor for the upgrade (approx. '10-'13). The retrofit part numbers are model and year dependent.
Huggerbugger
Oct 30, 2018 08:03 AM
1987 FLHS
Feb 6, 2014 09:26 AM
Pastor John
Jul 8, 2011 07:07 PM
soundman
Mar 10, 2010 02:54 PM
oregonrider
Nov 11, 2006 09:08 PM
