Well the dealer was able to actually reproduce the issue and they have a fix. It appears as though one of the ignition wires was loose and that was causing the issue. Im hopefully going to pick it up today and really give it a run this weekend and see how it goes.
[/align]I have a 02 RK and in 03 the same problem. I had it at the dealer six times finally they found the problem. Same as gibbyflhx had, in my case it was the ignition wire for the front cylinder.[/align]
Ill tell you it has been really frustrating trying to get this fixed, thankfully I kept my cool and understood the dealer had the same frustrations. They understood this could be a serious saftey issue especially if the bike stalled in a low speed corner. Hopefully the info I get tonight will help anyone else that has been experiencing the same conditions.
