Spark PLugs
Old Sep 13, 2007 | 08:28 PM
acedantinne's Avatar
acedantinne
Default Spark PLugs
Question???? Can and does anyone know if you can buy 1 or 2 step colder plugs for 96?
If so what is Plug #? What make?
Thanks
07 RKC
Old Sep 13, 2007 | 09:56 PM
voodoodrug's Avatar
voodoodrug
Default RE: Spark PLugs
curiuos the other day and did a search on spark plugs and was amazed. many more posts to follow...Good luck
Old Sep 13, 2007 | 10:17 PM
dawg's Avatar
dawg
Autolite 4163 is one step colder 4162 is two steps colder. 4164 is the equivalent to the 6R12
Old Sep 14, 2007 | 04:36 AM
PapaTravis's Avatar
PapaTravis
What would be the purpose of a colder spark plug? And what the heck is it? [sm=dontgetit.gif]
Old Sep 14, 2007 | 06:56 AM
NCCopBikeRider's Avatar
NCCopBikeRider
A colder plug retains less heat in the plug
Old Sep 14, 2007 | 07:32 AM
RDM's Avatar
RDM
Here is some info I found a while back. I'm not sure who the author is but it wasn't me.
SPARK PLUG HEAT RANGE
The "heat range" of a spark plug determines how hot the plug runs during normal operation. If the heat range is correctly matched to the engine application, the plug will run hot enough under normal driving conditions to burn off fouling deposits before they can cause problems. Likewise, the plug will not get too hot and become a source of ignition causing engine-damaging preignition and detonation. If the heat range is too cool for the application, though, fouling deposits may build up faster than they are burned off.
For this reason, always follow the vehicle manufacturer or plug supplier heat range recommendations when selecting a spark plug for a particular application. Two spark plugs may appear to be identical on the outside but have entirely different heat ranges.
There are situations, though, that may require a slightly hotter or colder plug than the one normally recommended. Switching to a slightly hotter plug can help reduce fouling in an older engine that uses oil, for an engine that spends a lot of time idling or is used for short trip stop-and-go driving. But a hotter plug should not be used unless an engine is experiencing a fouling problem because of the increased risk of preignition and detonation.
For performance applications (racing, or engines that are run under heavier than normal loads or at high rpm for sustained periods of time), switching to a slightly colder plug can minimize the risk of preignition and detonation. Even so, a colder plug can increase the risk of fouling with extended idling and low speed operation.
Many of today's spark plugs have a very broad heat range because the plug manufacturer uses a copper core or platinum center electrode. Copper is an excellent conductor of heat, so the insulator can be designed to run hotter and burn off fouling deposits without it getting too hot under increased load to cause preignition or detonation. A solid platinum center electrode will also carry heat away from the tip, but not if the electrode only has a platinum tip.
Old Sep 14, 2007 | 09:48 AM
NCCopBikeRider
Ditto what RDM posted
http://www.densoiridium.com/heatranges.htm
Old Sep 14, 2007 | 08:07 PM
Pete7539's Avatar
Pete7539
Ditto NC cop, Denso iridiums rock
Old Sep 15, 2007 | 02:01 AM
PapaTravis's Avatar
PapaTravis
Thanks guys, that really helped me to understand it.
Old Sep 16, 2007 | 01:52 PM
acedantinne
Thanks I'm trying to get a different burn.Trying to stay stock.
