HD Security System
Old Sep 14, 2007 | 11:05 AM
Dagrounds's Avatar
Dagrounds
Default RE: HD Security System
You do need to take it back to the dealer and get it reprogrammed. I have had trouble with my 07 system from the start. My system will not recognize my fob unless the batteries are super fresh. They only last 1-2 weeks and then I have to disable the system with the code for it to start. My fobs have been replaced and that did not solve the problem. I posted the issue here and found that most folks go a year or more before changing the batteries. Bottom line is the system does indeed need to sense the fob before it will allow you to start it......
Old Sep 14, 2007 | 11:27 AM
doghog's Avatar
doghog
Well, when I 1st turn it on the little key symbol light in the speedo lights up. Isn't that suppose to let you know that it recognizes the fob?
Old Sep 14, 2007 | 12:36 PM
mchildree's Avatar
mchildree
I think that means it's searching for the fob.
Old Sep 14, 2007 | 12:45 PM
DanB's Avatar
DanB
Another nice thing about the security system is that when it arms itself you get 2 chirps...sorta lets you know it works. Same when you unarm..more chirps to let you know its unarmed. This sequence has to be set up, it's in the manual.
DanB
Old Sep 14, 2007 | 01:15 PM
mllkn6's Avatar
mllkn6
What year did they start this?
Old Sep 14, 2007 | 01:42 PM
doghog's Avatar
doghog
OK that must be it- it must have never been programmed cause it has never chirped. Too bad they can't make it bark!
Old Sep 14, 2007 | 01:53 PM
jdtest's Avatar
jdtest
it only chirps if you have the siren.
Dolce
Electrical/Lighting/Alarm
Jun 8, 2016 08:03 PM
flyboyron
May 2, 2014 10:09 AM
KiloGolf4
Aug 26, 2012 06:10 PM
Blue Cross Bones
Jan 22, 2011 04:51 PM
MrNormal
General Topics/Tech Tips
Jan 7, 2008 10:04 AM
