Motorcycle Lifts
relli,
I went back and looked to be sure the title said "Motorcycle Lifts." I'm thinking of taking my Sears Redjack and doing some stabilitymodifications to turn it intoa more stable unit like the Pitbull. Even though I built afull size lift, having a stable floor jack is a must.
Take some 1/8 or 1/4 pipe collars and drill them so yourpivot bolts fit snug. I used 1/8" XH collars because I had them. I drill them to 3/8" and cut the length to fit inside the tubing or channel.
Everywhere there is a bolt running thru the lifting arms, slide the collar into the tubing and tack weld. Reassemble with some grease on the bolts. and shim the arms fairly tight to get rid of side to side play. This alone will make a world of difference.
Next item, make sure there is at least two horizontal supports on the front and the back, in order to tie in the two lifting arms. This will eliminate any horizontal or diaganol flex.
If you have a screw type pressure release, make you a large **** so you can slowly release the jack. If you have the spring loaded foot pedal, then I have no idea what to do to slow it down. I was thinking of some sort of orifice in the pressure release hole??? Dunno.
The jack will be rock proof, I promise.
relli,
Hey Rev00, Good ideas for sure. Using the 1/8" pipe collars is a quick and easyway to do this. I have the footpedal and I agree with you, it plain stinks for trying to slow it down. I'm thinking of retrofitting it with a jack that has a real flow control feature built in.
I also thought about cutting it inhalfto widening it to about 24", then lenthen it somewhat togive it less tendency to tilt or tip. Thanks for the tips.
Works perfect for my Street Glide
www.cyclelifts.com/CycleLifts/superjack/intro.htm
Simply the best.
Always keep two on the ground.
John
