Does the salesman know more
Old Sep 16, 2007 | 06:53 AM
Hogwallop's Avatar
Hogwallop
Default RE: Does the salesman know more
One of the nice things about the forum is being able to educate yourself about the product prior to visiting the dealer for your purchase. After a couple months of reading what people wrote here about the 07's, I found at one dealer, I knew 10 times more than the guy trying to sell me a bike. I ended up buying from another dealer who not only had the bike I really wanted, but was able to explain to me exactly what you fine folks have been telling me. Salespeople should know what they are talking about. If not, they are in the wrong business and shouldn't expect repeat business. Granted with new products, some sales folks don't fully understand new upgrades, but then again, isn't it their responsibility to educate us dumb consumers? Especially since the product has been on the market for a couple months now? I'm a little surprised that this guy knew so much about the engines, but struck out on the handle bar question. He should have researched the correct answer for you if he wasn't 100% sure. Maybe you should turn him on to this site for further product research...........
Old Sep 16, 2007 | 09:20 AM
dswansbiker's Avatar
dswansbiker
ORIGINAL: spizzyman
than the wrenches on the board?
I was at the stealer today and asked some questions regarding 07s and 08s, Ultras in particular. Here are some answers I received. Please let me know if you agree with them.
1. The 96 is the same size as the 88, just a longer stroke, therefore it would not be any hotter.
2.The same kit that turns an 88 into a 95 will turn a 96 into a 103.
3.A 96 has about 2 more HP than an 88. The only real difference is torque.
4.He does not know anything about a download from HD that will turn off the rear jug in traffic to reduce heat. Should he?
5. You can put any handle bars on the new bikes, no problem because the new throttle system is completely wireless and it would not matter at all.
6. said that it has been shown the IDS makes an Ultra run smoother than a Wing (Not sure how that came up. I didn't ask).
He is a seventeen year employee at this dealer and seemed to have never heard any of the questions I asked him regarding issues that I read about on this board. Didn't seem to think fuel managers or other things folks around here do to make the bike run cooler were necessary. He seemed to think folks don't know how to operate the vents on the lowers properly.
He is a nice guy and seems to sell a lot of bikes. Invited me to the Demo Day next month for test rides and is low pressure. I am just not sure if he knows less than the things I am learning here, is playing dumb or is on top of his game.
Input please.
spiz
1. same size? don't think so, its 8 cubic inches bigger, duh
2. same kit, not really, different part number kit for 96 engine vs. 88.
3. true, he got one correct.
4. yes he should know about the remap, especially if the dealership is in a hot climate.
5. not sure about this one.
6. smoother than the sewing machine Wing? Don't think so, and that is supposed to be a selling point? yuk.
Old Sep 16, 2007 | 11:12 AM
jammerx's Avatar
jammerx
SeeDonnys techline in the September 2007 American Iron almost all of those questions are answered there. Pages 44 thru 50.
Old Sep 16, 2007 | 11:26 AM
Softy's Avatar
Softy
There is something on the new bikes that will shut off the rear cylinder when the engine gets too hot,like from sitting in a lot of traffic. Moco's answer to running a bike very lean to comply with epa.
Old Sep 16, 2007 | 12:57 PM
iclick's Avatar
iclick
ORIGINAL: spizzyman
Incorrect. Same size bore, larger total displacement from the longer stroke. Longer stroke = more piston travel, thus more heat, all other factors being equal. Other factors are not equal, however. The closed-loop EFI that in the ranges where your bike is most likely to overheat is running an overly lean mixture of 14.7:1. That undoubtedly produces more heat than the longer stroke. EFI controllers can fix the heat issues.
Fundamentally correct. The '07 carries a different part number, I hear, although I'm told by an experienced wrench the earlier 95" jugs will work on the '07.
Sounds about right on the HP count, correct on the torque statement.
Yes, but he's a salesman, not a tech--so I guess he might deserve a pass on that one. On a second thought, he really should know fundamentals like this.
Well, it isn't wireless, it is cable-less. The signal is transmitted by a wire to the servo at the throttle body. I'm not sure how that would affect handlebar replacement except you wouldn't have to worry about throttle-cable lengths. You still have to worry about the wiring harness, clutch cable, and brake lines.
Maybe, maybe not--but that's sales BS. Probably doesn't really have a clue. The 96" engine with IDS is very smooth, or at least mine is.
Mine's a nice guy too, and I wouldn't go to anyone else for a new bike--but I wouldn't ask him any technical questions. He is totally clueless.
If he's honest and good at sales-related matters, go to him for that. Don't depend on him for technical info.
Old Sep 16, 2007 | 01:34 PM
chornbe's Avatar
chornbe
The "fly by wire" throttles still have a cable for the return. I believe they have to; That's a law/rule for safety and DOT certification (as I understand it).
The pull-to-open cable is replaced with a servo at the throttle body and sensor at the throttle handle. That's all.
Old Sep 16, 2007 | 01:41 PM
iclick's Avatar
iclick
ORIGINAL: chornbe
Thanks for that info, as I didn't know that. Where is the return cable, as its presence wasn't apparent on the '08's I've looked at. It must be more internal, unlike the cables on the earlier bikes.
Old Sep 16, 2007 | 01:51 PM
lp's Avatar
lp
Return cable? I don't think so....
lp
ORIGINAL: iclick
ORIGINAL: chornbe
Old Sep 16, 2007 | 05:11 PM
Roofuss96's Avatar
Roofuss96
Do your very best to go into a dealership / bike shopping as educated about the bikes as possible ~~ this forum is a good place to start . Read ,listen ,ask questions {of people in the know} and absorb all you can before you even walk through the door, that way you'll know a bullshit artist as soon as they open their mouths and you can make your own "educated " decision .[sm=smiley20.gif]
Old Sep 16, 2007 | 07:23 PM
chornbe's Avatar
chornbe
ORIGINAL: iclick
ORIGINAL: chornbe
Harleys may not have one (single cable throttle??). Every other bike I've owned does, and I *thought* it was mandated. Perhaps not.
upwgdrb
Nov 17, 2018 04:28 PM
TOMMYBLAZIN
Engine Mechanical Topics
33
Jan 10, 2018 03:25 PM
texasrich27
Mar 8, 2013 08:49 AM
pachowder
Jul 15, 2009 04:02 PM
tsween
Aug 28, 2007 07:39 AM
