Spark Plugs
Old Sep 18, 2007 | 09:53 AM
grunt25inf's Avatar
grunt25inf
Default Spark Plugs
What brand/type spark plug do you use? I've been reading about platinum/iridium plugsvs standard plugs.Are they that good or is it just b/s? What do you think ?
Old Sep 18, 2007 | 10:01 AM
07SG's Avatar
07SG
Default RE: Spark Plugs
IMO plat/irid plugs are only better for longer life of the plug, not performance gains. As simple as it is to change plugs in our scoots, it is just not worth the expense.
Old Sep 18, 2007 | 10:02 AM
Lost1's Avatar
Lost1
ORIGINAL: 07SG
+1.
Old Sep 18, 2007 | 10:07 AM
NCCopBikeRider's Avatar
NCCopBikeRider
What they said
Old Sep 18, 2007 | 10:11 AM
NICK56's Avatar
NICK56
Just use the stock plugs... and change em at 10,000 miles..
Never any problem.
Old Sep 18, 2007 | 10:16 AM
dduncan180's Avatar
dduncan180
Stage III
Believe it or not some of the ECM's now days measure the resistance/volts of the spark plug/wire and can tell the difference. As cheap as the standard plugs are why change.
Old Sep 18, 2007 | 10:19 AM
Retired_Ted's Avatar
Retired_Ted
Master mechanic at our dealership will only use stock plugs - other plugs make trouble - even HD's own premium plugs have made problems. Might be fun to experiment though.
Old Sep 18, 2007 | 10:30 AM
Lil Truckr's Avatar
Lil Truckr
I've been using NGK Iridium plugs since my first plug change and have been very happy with them,their performance and longevity...
Old Sep 18, 2007 | 11:50 AM
EVOrider's Avatar
EVOrider
I've ridden a few Panheads, lots of Shovels, tons of EVO's, and few Twin Cams......I've found no difference between sparkplugs or even brands for that matter.
I recommend either the standard OEM plug or a cross-reference plug. If the cross-referenced plug is identical to the OEM plug....then it is fine to use. The OEM plug is manufactured by Champion for those that don't know.
A spark plug does nothing other than create the spark that is needed for combustion.
Old Sep 18, 2007 | 02:06 PM
LeadDoggy's Avatar
LeadDoggy
I figured that the OEM plugs from HD were Champion, that's why I do not use them. I have had problems with Chumpion plugs in my car and in my Harley.
Used Motorcraft, Autolite and Bosh. No problems with any of them. Just installed a pair of ACs in my 98 Classic. Working good so far....
sk1sk1
Jul 14, 2017 11:18 AM
jtNIGHTSTER1
Oct 1, 2013 09:05 PM
alaskajeff
Jun 13, 2007 04:17 PM
carlosjc401
General Topics/Tech Tips
11
Sep 28, 2006 11:11 PM
HDF Tech
Engine Mechanical Topics
Jul 2, 2005 03:48 PM
