Detachable fairings and Radio settings
Old 09-24-2007, 04:07 PM
RoadKing06's Avatar
RoadKing06
RoadKing06 is offline
Default Detachable fairings and Radio settings
All,
I've been planning on adding a detachable fairing and in doing my research I was thinking about when the fairing is removed how does the aftermarket radio keep its time and presets? Anyone notice this and how did you get around it?
thanks in advance!!
Old 09-24-2007, 04:15 PM
prc1333's Avatar
prc1333
prc1333 is offline
Default RE: Detachable fairings and Radio settings
on the 2008's with GPS and XM, the time and date stays after battery detach and hook up. Not sure that is the same for pre-08?
Old 09-24-2007, 05:38 PM
RoadKing06's Avatar
RoadKing06
All,
I've been doing some research and maybe an electrical wiz can confirm, I found that with a 9volt batter attached to the memory lead it will retain its settings. Can anyone confirm?
Ram's Avatar
Ram
Ram is offline
If you have a detachable fairing with a Cig lighter, you can use the item in the link!
http://www.realtechnews.com/posts/2144
edit: AS long as the lighter outlet is hot all the time! (could be wired as such if not)
Old 09-24-2007, 06:02 PM
RoadKing06's Avatar
RoadKing06
Thanks for the response! Do you know if there is any logic in that connector or is it just a 9v on the end of the cig adapter?
Thanks!!
Old 09-25-2007, 06:32 AM
gunnert's Avatar
gunnert
gunnert is offline
1. Unless you wire it up, none of the detachable fairings will keep their presets
2. I'ts a mute point, once youput it on, you won't be taking it off....
Old 09-25-2007, 07:30 AM
jskwarek's Avatar
jskwarek
jskwarek is offline
No logic just a 9 volt battery on the hot wire to keep the memory live when it is not hooked to that bikes battery, but like Gunnert said. Most of the people that I know that have added after market "Removable" fairings added them and never took them back off.
Jeff
Old 09-25-2007, 07:32 AM
RoadKing06's Avatar
RoadKing06
Thanks everyone!!!!
Old 09-25-2007, 05:22 PM
Ram's Avatar
Ram
Ram is offline
ORIGINAL: gunnert
True, been there, done that.
And as logic for battery, only polarity and thats it, may have a diode to keep any 12 volts from going back into battery an over juicing it (like charging it). 9 volts is just enough for keep alive of memory settings nothing else.
For that matter you could just wire one into the back side of the fairing an secure with velcro, don't forget the diode.
nkfd13
03-18-2011 05:15 PM
RoadKingClassic2001
01-09-2010 05:24 PM
swaite
06-28-2008 09:31 PM
Lord Albany
05-05-2008 11:44 AM
Desperado
01-27-2006 08:28 PM
Quick Reply: Detachable fairings and Radio settings
