K&N replacement
Old Sep 24, 2007 | 08:21 PM
vettedog72's Avatar
vettedog72
Default K&N replacement
Does K&N make a replacement filter for the OEM? Does the brand of the back plate make any difference in performance?
Old Sep 24, 2007 | 09:27 PM
glens's Avatar
glens
Default RE: K&N replacement
http://www.knfilters.com/search/prod...x?Prod=HD-1499
Yes, the airbox assembly makes a difference for performance. The stock airbox has a relatively small opening compared to "stage 1" kind of stuff, but it has sufficient flow for stock tuning/exhaust, even with the replacement filter above (which really won't change intake flow characteristics enough to matter as far as needing a "download" flash, or other type of fueler).
Old Sep 25, 2007 | 09:07 AM
NCCopBikeRider's Avatar
NCCopBikeRider
K & N makes a replacement filter for the stock Harley filter, a replacement air filter kit #3909 and athicker filterkit the #3910.
All three are great options for any bike
Good Luck
Old Sep 25, 2007 | 10:11 AM
gene01's Avatar
gene01
the difference in the backing plate is the velocity, there is a rubber boot that is about 2 inches deep creating a veturi effect that almost forces more air in in addition to the actual filters ability (being large) to allow more air into the engine, (more air in more volume out) = more horsepower I use the 3910 on my bikes uses the factory cover and looks nice, does stick out about 2 inches more than factory position though...
Old Sep 25, 2007 | 10:19 AM
glens's Avatar
glens
The velocity stack is an impedance-matching device. It allows the graceful transition from the low-velocity/high-pressure (low impedance) condition inside the airbox to the high-velocity/low-pressure (high-impedance) condition inside the runners. Same thing as properly-designed horns on acoustic drivers. Much greater efficiency that way.
Old Sep 25, 2007 | 11:17 AM
ultra96rider's Avatar
ultra96rider
The K&N HD1499 OEM air filter unfortunately compresses the two beather hoses due to the holes on the back of the air cleaner being narrower or closer together that stock. Stock is 5", K&N is 4 11/16 " which doesn't sound like much until you see how the hoses are compressed after installation. This causes additonal back up pressure which is not a good thing.
I have been trying to deal with K&N over this matter for nearly two years. They have acknowledged the difference in center to center breather hole measurement but have not been very interested in correcting it.
Other filters out there for OEM replacement measure the OEM 5 ".
Hope this helps.
leenanj
Aug 19, 2016 05:26 PM
prezflyr
Mar 1, 2014 11:11 PM
fmf979
May 4, 2012 10:30 PM
Matt0987
Exhaust System Topics
Jun 16, 2011 01:49 PM
artz
Apr 22, 2011 07:12 PM
