Fairing Mirrors Removal
Old Dec 4, 2005 | 02:44 PM
Cohiba_Joe's Avatar
Cohiba_Joe
Default RE: Fairing Mirrors Removal
Hey Mike (Wally)....
If you decide to have the fairing mirrors removed, the best way to fill the holes is to start from behind the inner fairing. Either epoxy something to cover the holes or use fiberglass mat and resin. You want to have the holes covered first. From the front you will have the holes but they won't be trough-holes. Then you would use a standard body filler to actually fill in the holes. Make sure to feather edge the filler out past the circumference of the holes otherwise you could end up with the filler popping out. I've never seen a stock inner fairing but for some reason I thought they were textured. If so, the texture can be replicated using a number of different methods depending on the texture pattern. You would want to texture the body filler as it's drying.
Brian
Old Dec 4, 2005 | 11:44 PM
Wally's Avatar
Wally
Thanks alot!
Old Dec 5, 2005 | 12:33 AM
mikeisglidn's Avatar
mikeisglidn
i sh*t canned my handle bar mirrors and added the faring mirrors. id never go back! just me tho
Old Dec 5, 2005 | 11:52 AM
CHEYENNE's Avatar
CHEYENNE
Can't they be plastic welded closed??
Ultra Pearl
Aug 3, 2014 05:18 PM
speedracer
Feb 13, 2014 08:49 AM
kjkustoms
Touring Parts
Feb 18, 2011 07:55 PM
RCopeland1
Apr 7, 2008 12:37 PM
bonzo2
May 14, 2007 12:14 AM
