How do you unplug the headlight...issues
Old Sep 27, 2007 | 01:09 PM
swipter's Avatar
swipter
Default How do you unplug the headlight...issues
When I installed the cruise on my SG I could not get the headlight bulb unplugged. The service manual says to grasp the plug and squeeze and pull. I have read others here that talk about working it back and forth. What part do you squeeze....the top or the bottom of the plug? It shouldn't be that hard to get out. It isn't blown but my son does get tire of standing there holding the front end when I have to take it off for whatever reason.
Thanks
Old Sep 27, 2007 | 01:15 PM
Motown_HOG's Avatar
Motown_HOG
Default RE: How do you unplug the headlight...issues
You should be able to just grab hold of it and pull hard (grab the rubber boot portion of the plug). It will come right off- or at least should!
Old Sep 27, 2007 | 01:24 PM
Akitakoi's Avatar
Akitakoi
Yup, ya gotta pry the rubber off!
Old Sep 27, 2007 | 01:25 PM
sugarbear's Avatar
sugarbear
I had the same problem. I took a small screwdriver and wedged in between and worked it out that way.
Old Sep 27, 2007 | 01:39 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Light Contacts may be "weleded" to the contacts in the plug.
A small screwdriver, inserted gently between the headlight and the connector may be the answer.
Don't pry too hard as you will likely break the reflector.
Old Sep 27, 2007 | 01:58 PM
Retired_Ted's Avatar
Retired_Ted
Some of the plugs have little"ears" (located on the sides of the plug) on them that you have to press while pulling. Before you put it back together (assuming you get it apart), put some silicone grease on the lamp pins.
Old Sep 27, 2007 | 02:37 PM
NCCopBikeRider
RT
Would dielectric grease work as well as silicon?
Thanks
Old Sep 27, 2007 | 03:13 PM
swipter's Avatar
swipter
ORIGINAL: Akitakoi
Didn't think you had to pull the rubber out too or at least it would be that hard to do.
Thanks
Old Sep 28, 2007 | 06:24 AM
Warden's Avatar
Warden
Squeeze the sides and pull. No problem. Rubber boot is a seperate piece. Just had mine off last night.
Old Sep 28, 2007 | 07:00 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
First time it can be a little stuck, she'll loosen up after that.
