pinging question
Old Sep 27, 2007 | 04:58 PM
jeffer60's Avatar
jeffer60
Default pinging question
I have an 07 ultra classic with d&d fatcats, ANBS stage 1, and thundermax autotune. I get pinging when I take off in first gear when hot and also between 2000 and 3000 rpm when i crank on the throttle to pass or something. Is the bike set too lean? Called TMAX tech support a while back and told them my setup, and he said not too lean and could not explain it.
Old Sep 27, 2007 | 05:03 PM
coolnite's Avatar
coolnite
Default RE: pinging question
It's not necessarily "to lean", it sounds like you have too much spark advance under some circumstances. Try to determine the exact conditions that cause the pinging and then go into the T-Max advance table and reduce the advance by 2 degress in those cells. Make small adjustments to only a few cells at a time.
Old Sep 27, 2007 | 05:12 PM
dagnabit9's Avatar
dagnabit9
That was happening to me on my '06 Ultra after installing a FuelPak (along with the stuff listed below). Called the tech support people and they gave me some tweaks to use on the programming - hasn't pinged once since...
Jason12flh
Oct 5, 2012 09:34 PM
robmil07
Dec 31, 2011 10:08 AM
Robottom
Jul 6, 2009 10:26 PM
geedub
Sep 9, 2007 09:23 AM
*JC*
Oct 28, 2006 09:59 PM
