Finding Neutral Gear
2007 RG 1500 miles. Was out riding the other morning and got stuck in heavy traffic - 30 minutes stop/go. Started having trouble finding neutral - never experineced this before. At 1000 mile service had royal purple oil put in and belray trans fluid (70/140)
Is this "normal"?
Thanks
Stay defensive and ride lots! JW
taterdog,
he has an 07, no adjustment to the chain....
but would recomend to anyone "in traffic" to NOT be in neutral. I would rather stay in gear, stay on the clutch, and keep an eye on the rear view mirrors, and find that escape route every time for when you hear the inevitable squeeling tires coming up from behind!
In the scenario where you wind up in a line of traffic with vehicles in front of you, "staying in gear" serves no purpose whatsoever. If someone comes careening up behind you with no obvious intent to stop behind you, where are you going to go? You're blocked from the front - are you going to try some sort of stunt to exit off the either side? That's gonna' be fun to see.
What if you happen to be the first vehicle at the intersection and another vehicle comes up from behind and doesn't stop? You goose it to try to get away, and what happens next? You wind up in the middle of the intersection with cross-traffic moving through it, and someone T-bones you.
Either way, the outcome is VERY questionable, and I'm not convinced the probabilities of a GOOD outcome outweigh the added wear and tear of holding in the clutch for the amout of time involved, which, in many cases, can be 10-15 minutes or more.
So I go against the grain here. I go to neutral, and first when the signal changes. What do I know? I've only been riding 50 years.
And I don't care what you say, sometimes at a trafic light I'm going to flip it in neutral. I put a fish scale on it this week. It takes 20 lbs to pull it in.
