air suspension pump
Old Oct 1, 2007 | 09:42 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: air suspension pump
Yes & it works GREAT....
Recommend you keep it in your saddlebag and check your pressures before every longer ride if not more often...
Old Oct 1, 2007 | 09:59 PM
stephenabel's Avatar
stephenabel
Thanks for the recommendations. Guess I know what I'm buying next. It never ends.
Old Oct 1, 2007 | 10:31 PM
sanaga's Avatar
sanaga
always use lighter socket air compressor, dont have hd one....
HDRider#1's Avatar
HDRider#1
Use to use the kids bike pump, real pain in the a$$, one time I'd get 3lbs... next time 20lbs. All over the place, couldn't get what I wanted. Picked up the pump $60.00 cdn,now I can adjust to 1/2 lb incriments. Remember 35lbs is the max according to owners manual.
Old Oct 1, 2007 | 11:00 PM
SIM's Avatar
SIM
get it and keep it in your saddlebags..worth the $$
Old Oct 2, 2007 | 01:17 AM
PapaTravis's Avatar
PapaTravis
I use a bike pump. Haven't spent the money on the hd one, yet. You might try http://www.zanottimotor.com/or http://www.chicagoharley.com/shop/to get 20% off. BTW, my bike pump works just fine. No air loss, except when I check the pressure, lol. Guess I figured out a stocking stuffer for myself.
Old Oct 2, 2007 | 05:23 AM
dt20's Avatar
dt20
just picked one up the other day myself. man makes it really easy to add or remove air still trying to find my sweet spot so Ive been using this for the past couple days as when I first checked my shocks they were at 0psi.
Old Oct 2, 2007 | 05:41 AM
curlydee's Avatar
curlydee
The Moconese got that right.
Old Oct 2, 2007 | 07:51 AM
Rollon's Avatar
Rollon
Get one, well worth the $. I have a compressor you can set the outflow pressure and use it on your shocks (limit it to about 20 lbs for shocks). But the pump allows you to pump it up and down with a lot more control.
Old Oct 2, 2007 | 08:40 AM
mps1168's Avatar
mps1168
I agree as well, get the pump. I put a couple of sticky back zip tye bases under the cover of my side bag, cut two strips of velcro and mount the pump in the cover lid. Easy and out of the way and always with you.
mps
