07 Ultra exhaust Question
Old Oct 7, 2007 | 10:09 PM
  #41
drdiesel1's Avatar
drdiesel1
Default RE: 07 Ultra exhaust Question
[quote]ORIGINAL: glens
ORIGINAL: drdiesel1
Yes. Everything you are stating is true, but the same thing remains. +/- 3% is still not even close to +/- 0.5% That's the limit as stated by the SERT data provided, yet you choose to ignore it. You come back with spiel about the VE-New table being able to adapt to control the AFR tables within a given spec, but know-where in the SERT data available to me can this be verified.
The SERT users manual states "switching sensors can only control within a narrow range (+/- 0.5 AFR)". +0.5 AFR (from stoich, the center of the range) is 15.2 AFR or -3% fuel [14.7 ÷ 15.2 = 0.97] and -0.5 AFR is 14.2 or +3% fuel [14.7 ÷ 14.2 = 1.03]. That's the limit, which I'm not ignoring. It's also not the function I'm describing. But remember that, the usable reporting range of the O2 sensor is only 3% in either direction from the midpoint.
The SERT manual mentions the VE-New how? It says it's calculated when running closed loop. Does your copy explain how it's calculated? My copy doesn't. Does that mean it's not really happening or does it just mean that it's impertinent to the SERT because it's yet another of the things the SERT cannot touch?
I'll attach an image I picked up from some post here a while back. Note the "VE Front" is 86% while the "VE New Front" is 81.5% (94.8% [=AFV for that cylinder] of the set value) while the "O2 Integrator Front" shows no deviation from setpoint which appears to be 0.56V. That's -5.2% deviation from set VE, almost the total range of "control" available from the O2 sensor! Yet the usable range of control from the sensor in establishing the "VE New" in any direction is only half the total O2 sensor range available, which makes the deviation represented nearly twice the range of the O2 sensor for that direction. How does the VE New get that far away if it's being "controlled" only by the O2 sensor, especially when the sensor is at its CLB value (evidently)? I contend that the sensor is at its CLB value because the VE New, and not the VE, was used to calculate the injector duty cycle. The VE New controls the O2 sensor output, yet the sensor output helps establish the VE New (via the currently-adjusted AFV). None of how that operation takes place is described in the SERT Manual yet it obviously happens.
Look at that again. The VE New is almost twice the distance in percentage of what the O2 sensor can measure in that direction from its midpoint (which it's not even set at; I believe where it's set and the direction of the VE New would result in greater than twice the available range of the O2 sensor in that direction; but even if the "headroom" in the sensor output toward the other direction from its setpoint was used it's still less than the resultant AFV).
You seem to give a bigger window of AFR/VE than the actual limits/info available. You have a very good habit of allowing more head room than what the actual operating parameters suggest. How about some Bona-Fied info/data parameters to back it up with. I have given you the proof you asked for, so maybe you could as well.
You're the one of we two who has a SERT-equipped bike. You could data-log and see for yourself. So far the only instance of that I've been able to scrutinize is included here and discussed above. That's hard data/proof. Though not proof that my specified range limits are correct. But you could easily verify that yourself. I'll leave it to your imagination as to how to go about it. (something like zip-tying some non-flammable fabric around the end of the muffler and data-logging a trip around the block ought to suffice and be harm-free enough)
As I've previously stated, I don't have access to the HD Delphi engineering documentation so I can't provide you with proof that way. I do know, however, from other creditable sources it probably wouldn't do much good to drag into this, that the range is ±15% for
Old Oct 7, 2007 | 11:07 PM
  #42
glens's Avatar
glens
ORIGINAL: drdiesel1
OK..Thanks for acknowledging that fact....I knew it was not available and needed to hear you say so. ...Just needed to prove my point that this is an unknown area of change. ...It`s not available information and without proper verification I suggest otherwise.
I guess I'm not sure I understand which fact I acknowledged At any rate, the the area of change and the information regarding it, while not readily available as official documentation, is somewhat known. I'm trying to help in that regard.
Thanks for all your input on this subject. Although some may feel it was an unnecessary thread. I think everyone including myself has a better insight of the ECM`s functions and control capability's. For those who care...[&:]
Hell, I don't care. Hahaha!
Really, though, you're quite welcome. It's been a real pleasure. Having to put this stuff into terms which clearly convey the concepts to others has been a great exercise for me, as should be evident I still need work on but feel I'm maybe getting somewhat better at. I have a tendency to imply a great deal with my words and it's not only here that it gets me into trouble sometimes.
Ironfeather
Stock Harley Take Offs
Jul 8, 2016 02:30 AM
BOSSMAN
Exhaust System Topics
May 18, 2009 08:14 AM
ytsultra
Nov 20, 2008 03:10 PM
az232
Mar 2, 2008 07:41 AM
heybigb
Apr 10, 2007 08:56 PM
