Oil filter
Old Oct 7, 2007 | 06:59 PM
brinks13081's Avatar
brinks13081
Default Oil filter
How tight should the oil filter be, is hand tight good enough?
Old Oct 7, 2007 | 07:07 PM
maineultraclassic's Avatar
maineultraclassic
Default RE: Oil filter
As tight as you can get by hand is plenty, that way you'll have no problems removing it next time.
Steve
Old Oct 7, 2007 | 07:13 PM
brinks13081
There seems to be a very small dot of oil on the ground everytime I warm the bike up. I think its some residual oil from when I removed the old filter and spilled a little but i'm a little concerned. I can't see any leaks anywhere.
Old Oct 7, 2007 | 07:14 PM
madurodave's Avatar
madurodave
Turn until the gasket seats, then add 1/4 turn. That is roughly hand tight. That should work great.
Old Oct 7, 2007 | 07:30 PM
TexasRedneck's Avatar
TexasRedneck
Didja lube the gasket/oring first, or put it on dry. Ya should always wipe it with a dab of fresh oil afore installin'....
Old Oct 7, 2007 | 07:33 PM
brinks13081
Yeah I did, but I also spilled a little when I removed the old filter, I really hope that is it.
Old Oct 7, 2007 | 07:49 PM
Drum's Avatar
Drum
Brinks, it must be drainage from when you pulled it off. I always spray simple green in the area below the filter when I'm done and hose it off.
eviltwin415
Sep 25, 2017 11:55 PM
deadman77
Oct 18, 2015 06:45 AM
soloman96er
Jun 16, 2009 08:22 PM
Gmansitur
Jun 28, 2007 05:42 AM
vtxed
May 14, 2007 02:48 PM
