It's a standard male/female plug, where the exposed male end is the negative, and the insulated female end is positive. Just look, it's right there ! Mine came with a dirt cap over the end. It's fastened direct to the battery, with a fuse in the harness for protection. Your Battery Tender has the same plug on it.
Does any one know where toget a few of these pig-tails for the battery side and one for the charger side as I already have a battery charger? Thanks if you know.
As other have posted, you already have the plug on your bike. To answer another question posted, Delran (mfr of battery tender) sells the ring terminal/quick plug separate as well, so you can use your tender on multiple bikes. As much as I despise Parts department Unlimited, any dealer who has PU as a supplier (almost every does) Custom Chrome is the name for PU at Harley stores, can get you as many sets as you want.
The plugs do not come installed by he MOCO. Many dealers install the plugs at time of the PDI set up. The harness does not come with the new battery tenders. It must be purchased seperately. Part number is 94624-97B. The cigarette lighter is switched power, so you would have to charge with the switch on acc. One step forward, two steps back. The harness is too simple to hook to the battery. It only takes a few minutes.
HD dealer sells the pigtaials that attach to battery for about $6 so you can use the same tender on multipul bikes,etc. Some auto parts stores sell them too.
