Running lights for a Street Glide
Old Oct 13, 2007 | 09:01 PM
timidones's Avatar
timidones
Default RE: Running lights for a Street Glide
I added the HD off road blub, and adjusted it higher..it helped lots
Old Oct 13, 2007 | 09:57 PM
swipter's Avatar
swipter
ORIGINAL: drdiesel1
ORIGINAL: celtlion
The low beams on my SG aren't cutting it for night riding so I'm planning a winter upgrade to add auxiliary running lights.
Any suggestions?
Adjust the head light up so you can see.[8D] You`ll find you don`t need aux lamps. Try it and see.
Adjust it up and to the right an inch and you will be fine.
Old Oct 13, 2007 | 10:57 PM
Lu's Avatar
Lu
ORIGINAL: CREEPSHOW
I'll sell mine!
How much
PM sent
Old Oct 13, 2007 | 11:31 PM
Harleypingman's Avatar
Harleypingman
If you want to keep the SG look, consider the HD fog lamps that mount on the engine guard. They are 55W each compared to the passing lamps' 35W. Different light pattern, but they work well. I have both passing lamps and fog lamps on my '04 EG that are always "on" so cagers can see me day and night.I have tried turning one or the other off at night to see the difference in light and, if I wanted to preserve the SG look, would find the fog lamps a good alternative to the passing lamps. The fog lamps provide great lateral light which I find useful at night on rural roads.
Old Oct 13, 2007 | 11:43 PM
CREEPSHOW's Avatar
CREEPSHOW
[/quote]
How much
PM sent
[/quote]
I sent you a PM but I would like to add this option, trade them even for your SG front turnsignals and stock bracket.
Old Oct 13, 2007 | 11:52 PM
Lu's Avatar
Lu
ORIGINAL: Harleypingman
Those fog lamps look great, although, I want to get lowers. Hope Mrs Claus gets me a pair for this Xmas
Old Oct 14, 2007 | 12:19 AM
Harleypingman
The main reason I don't have fairing lowers is I hate to give up the fog lamps and Moto lights, although a great alternative, are $300--ouch.
Old Oct 14, 2007 | 12:30 AM
61panhead's Avatar
61panhead
I installed passing lights on my SG after less than one month.
It made a BIG DIFFERENCE.
I was concerned about deer standing on the side of the road, hiding in the edge of darkness, andjust waiting to jump in front of me. My high beam puts a very small spot in the road and the passing lights allow me to see more at a wider angle.
I used the clean looking mounts from HD.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
I wired into the ignition switch so that I don't accidently leave them on in the daytime and run down the battery.
The dash switch gives me control of them all the time, high beam, low beam, or not.
Looks are subjective, but I thought the SG was missing something. It looks better to me WITH the lights.
Old Oct 14, 2007 | 08:30 AM
Duracell's Avatar
Duracell
That link sayes they won't fit FLHX?
Old Oct 14, 2007 | 08:42 AM
Lu's Avatar
Lu
This one is for FLHXs
[align=left] [/align]
