FRONT END WOBBLE
Rear end weave can be caused not only by the lack of a third link on the rubber mounts causing the swingarm to move sideways on a sweeper, but also bad swingarm bushings, cracked swingarm, low tire pressure, bad tire, tire outof balance,bad shock or shocks, and improper alignment, which was an initial problem with many of the TC88's, coming from the factory with as much as a 3/4" difference in the tracking of the front to rear tire (as first reported by MCNews way back in '99) caused by the motor mounts not adjusted properly at time of build.
Harley isn't the only bike with wobble issues. The early model Yamaha Ventures were notorious for a front end wobble when slowing down due to a too light fork brace (corrected by installing a SuperBrace) and the current Gold Wings have a similar problem, now thought to be caused by uneven internal wear in their front forks. They have a spring in only one side of their fork, and the dampening cartridge in the other, causing uneven action in the forks.
Check your bike from one end to the other. It's gotta be caused by something. If anyone has ever had a tank slapper, like I did on my T150 Triumph, you know it's nothing to fool with.
Has nothing to do with the FIX, IDS. Its a problem with all rubber mounted HD bikes. This is a FACT.
Please check out the True Track or straight8 web sites. The problems are explained Why, how it happens and all the tech stuff you need to know about this Wobble. Has to do with rubber mount isolators in the swing arm moving in coralation to the rubber mounted engine.
Eric Buel told Harley they need a rear engine mount years ago. That is why he has added to his bikes.
This is what the www.ridestr8 and the true track does.
You will get alot of douting thomas on this 1. The problem is there. Ride normal, speed limit so to speak and it wont be to much of a big deal. The wife and I noticied when bike is loaded, for a trip. Pulling off exit ramp, a sweeper as it was. Take extra caution. Knowing its can happen. Wobble.
No softtails dont have the same problem. Rear swing arms do not have rubber isolators.
Ride safe and have fun.
The information I read on the two references sites mention worn rear swingarm bushings however the lack of a solidly attached rear motor mount coupled with worn bushings is what leads to the issue known as "rear steer".
Many years ago HD made changes to the swingarm bushings to slow the wear rate and distortion.
As stated, many many items can contribute to a wobble at either high or low speeds. To just do a knee jerk reaction and claim the install of a third party device such as a ride straight or true track will eliminate it is false. If the wobble stems from bad or loose neck bearings, strapping down the engine won't fix it.
I have felt the Ultra get a little "snakey" in certain curves. Usually it is brought on by a change in geometry when the suspension loads or unloads. This can be caused by throttle movement, braking, weight shifts, and pavement changes. Sometimes adding throttle is the answer, other times reducing is the answer. It depends on what change to the suspension geometry brought it on to begin with.
Leaving Americade this year traveling down 97 bike is loaded. Around 75 mph.Hit gap, hole in highway front of bike started shaking real bad. Like losing control. Slowed down to 40 mph to gain control.
rode home no more problems.
Riding back from nephews out 80 doing about 70 mph. turn to get off at White Haven same problem front of bike start shaking back and forth. wife is in my ear. I,m bring the speed down. Again, down to 40 mph to gain control.
Yes the head bearings are adjusted right. Tires front 38# rear 40# shocks 20#. I have found out if you run lower shock pressure my bike willresponded with the shakes. On 2 up riding. I believe front end a little light? No the wife and I are not to heavy weights. We do not come close to the recomended gross total weight. Never had this problem with any other Harley we owned. Softail handle like a dream. OkIbottom the floorboards out a few times. Normal
Dealer: never heard of this. Guy standing near counter. Outside tells me his RK does the same thing when 2 up riding.
thanks for the correction. It is the anti-dive unit onthe leftside, and the fork cartridge on the right side, causing this problem, along with light materials, and an inadequate triple tree clamp. There is a fork spring on each side. MCNews, March 2007, describes their front fork as the same size you would see fitted to a 600cc sport bike, with even some part numbers the same as the GSX-R600.
