08 Stereo question / idea?
Old Oct 15, 2007 | 09:28 AM
BAGTHIS's Avatar
BAGTHIS
Default 08 Stereo question / idea?
I have an 08 SG on the way.I see that a lot of people are installing 6x9's in their saddle bags and adding an amplifier to the stereo system.I would like to do the same thing, butIam looking to do it in steps and save a little scratch to start out as there are a bunch of itemsI need for the bike. So here is my question, is the stereo on the SG the same as the stereo on the UC? In other words, does the deck have 4 channel output, but only using two because of only two speakers being available? Or can I run wires from the rear channels on the deck (not currently being used) to power a pair of 6x9's untilI have the scratch for an amp?
Old Oct 15, 2007 | 10:38 AM
RonH's Avatar
RonH
Default RE: 08 Stereo question / idea?
I don't think the stock radio has 4 outputs. I believe the Ultra has a second amp under the tourpac for the rear speakers.
Old Oct 15, 2007 | 12:02 PM
BAGTHIS's Avatar
BAGTHIS
Really? I can't imagine Harley spending the money for an additional amp. If this is the case, it sucks for me. How much room is in the fairing of a SG for an amp? Thickness, length and width if anyone knows. Thanks for the info, and thansk in advance for any more info!
Old Oct 15, 2007 | 12:19 PM
gabhart's Avatar
gabhart
I have a '07 Ultra and I have never run into a second amp for the rear speakers...at least under the tour pak.
Old Oct 15, 2007 | 12:21 PM
gunrunner's Avatar
gunrunner
ORIGINAL: RonH
No external amps on ultras it just a higher out put radio. I think some of the earlier SE Ultras might have had one but not the standard ultra models.
Old Oct 15, 2007 | 12:22 PM
swipter's Avatar
swipter
ORIGINAL: BAGTHIS
I must have missed all those tags. Installing 6x9s in the saddlebags?
Old Oct 15, 2007 | 12:23 PM
FLHT's Avatar
FLHT
The stock radio has capability of front and rear but you have to pay the dealer to activate the rear channels
Old Oct 15, 2007 | 02:00 PM
BAGTHIS's Avatar
BAGTHIS
FLHT,
That's the answerI was looking for. I new they were two cheap to offer different kinds of stereos. The are going to swap out my front speakers and install the painted inner fairing for me, soI am going to have them run some wire an coil it up under my seat ustilI get the bags either cut or drilled for 6X9's. That wayI can determine ifI want to throw more money at it and go with and amp (sony makes a slip 4 channel thats 8 1/2" x 7 1/2" x 1 3/4" if it will fit) later on down the road, or leave it as is. Does anyone know how much room or what kind of space is available in the fairing,I do not want to mount the amp in the saddle bag soI can keep some storage space!
Old Oct 15, 2007 | 02:36 PM
MassHD's Avatar
MassHD
You can mount the amp right on top of the radio inside the fairing. Thats where Hog Wired and Hog Tunes put it.
Old Oct 15, 2007 | 03:27 PM
SoCal_Pappy's Avatar
SoCal_Pappy
You have room under the fairing for a small amp... Most auto amps will run on the HOT in the fairing area...
HawgWired or Hog Tunes do make amps made for Harley Motorcycles & Work WELL!
http://www.hawg-wired.com/
http://www.hogtunes.com/
