bike sounds different
Old Oct 16, 2007 | 12:16 PM
wrustywrench's Avatar
wrustywrench
Default bike sounds different
04 E-glide Standard.
Vance and Hines true dual, with megaphone drag specialites mufflers, no baffles.
carbed, screaming eagle ignition, carb is jetted and bike runs good.
BUT, it sounds like the rear cylinder is not firing all the time at idle. Just sounds weak. Did a compression test, 120 ( guage may not be accurate, but both are the same) in both front and rear. Motor makes no ticking noise. ( lifters)
I know the pipes are not the same side to side, but the bike deff sound different. Would the new ignition make it sould like its missing on one side at idle. IS the timing different. >>>
Seems to run fine down the road but does sound raspier just cruizin, NOW,, one pipe is blacker than the other, could there be an intake gasket leak??
Old Oct 16, 2007 | 06:45 PM
wrustywrench
Default RE: bike sounds different
come on give me some answers to ponder, fellers
Old Oct 16, 2007 | 07:01 PM
swipter's Avatar
swipter
Have you checked your coil wires to make sure one isn't partially grounding or maybe not completely attached? Had this on my Indian that was carbed. I don't know if a carbed Harley is set up the same. Mine would only do it sometimes.
Old Oct 17, 2007 | 04:58 AM
wrustywrench
I am going to the strealer to get new wires tonight,,,,,,and I will check new connections.
Some screamin eagle wires,. might was well.
Old Oct 17, 2007 | 06:11 AM
Taterdog's Avatar
Taterdog
Do the plugs look the same? Could you have a bad plug in the rear?
Old Nov 29, 2007 | 03:18 PM
White Knight 04's Avatar
White Knight 04
How did you adjust your boomcans for sound??? I see in a earlier post you have them... And did you get the missing figured out??
Thanks
Jer
84 FLTC
Shovelhead
Jul 18, 2014 08:20 PM
billzflhtc
EVO
Feb 19, 2013 08:01 PM
Gil-B
Sep 16, 2012 03:22 PM
ptcruiser
EVO
29
Nov 9, 2010 09:45 PM
Reckless Kelly
EVO
13
Jun 25, 2009 11:00 AM
