I have an electra glide with 88" EFI and I'm thinking of putting on bassani pipes now and big bore kit later what programmer should I put on was thinking of putting on a Dyno Power CommanderIII?????
I would look at the sert. If you want to go closed loop and have a sert, HQ's protuner is plug and play.
On the other hand you could go Tmax with autotune. With the sert it would need reprogramed with every change of component. On thetmax you would load in a new base map and go ride with the auto tune and it would calibrate it self. Hope this helps. Bob
To be fair, before discounting the PC-III and/or saying it will need dyno time, a search for a map already developed for those combination of pars should be performed. The PC-III is a great little unit and has a helluvalot of bang for the buck.
