True duals vs. slip ons????
Old Nov 1, 2007 | 09:39 AM
Crusher's Avatar
Crusher
Default True duals vs. slip ons????
Want opinions if true duals really offer that much more performance opposed to just adding slip ons. Is it worth the money?
Old Nov 1, 2007 | 09:51 AM
MACK's Avatar
MACK
Default RE: True duals vs. slip ons????
Slip ons will give you the sound and some upgraded performance but true duals will add a lot more when used with a hi flow and race tuner. Yes ,worth the money.
Old Nov 1, 2007 | 09:58 AM
gunrunner's Avatar
gunrunner
True duals will move your power band up to a higher level, in other words it will lessen your low end and enhance your top end power.
Old Nov 1, 2007 | 10:05 AM
stglideblk's Avatar
stglideblk
Tru duals will kill your torque unless you use exhaust cones.
Old Nov 1, 2007 | 10:58 AM
TexasRedneck's Avatar
TexasRedneck
ORIGINAL: stglideblk
Really? Then kin ya explain this?
[IMG]local://upfiles/19857/72AA230EF3CA4FD8ABA630F172392F25.jpg[/IMG]
Old Nov 1, 2007 | 11:06 AM
CKinAZ's Avatar
CKinAZ
ORIGINAL: TexasRedneck
I'll jump in and say that if you look at the rpm where your torque is peaking, its at about 3700 - as opposed to 3200 for a stock motor. Where did the bottom end go? Answer - you moved the torque peak up in the rpm range and lost bottom end......
Old Nov 1, 2007 | 11:13 AM
DonnyI's Avatar
DonnyI
True duals are well worth the money.
Old Nov 1, 2007 | 11:42 AM
TexasRedneck
Yep - but since we tour a lot, the upper band is whar ah wanted it....
csgohn
Exhaust System Topics
Feb 25, 2017 10:25 AM
gnewman
Dec 12, 2012 05:07 AM
Cannon00000
Jul 15, 2007 11:28 PM
fiddlinfool77
Mar 31, 2007 05:33 PM
skos
Jun 25, 2005 03:36 AM
