derby cover
Old Nov 3, 2007 | 08:11 PM
az232's Avatar
az232
Default derby cover
This is probably a stupid question but I am changing out the derby cover on my bike for a new one. Do I just unscrew the 5 screws and swap the covers or is there a gasket or o-ring in there that needs changed or is there anything in there that I need to worry about falling out?
Old Nov 3, 2007 | 08:15 PM
dawg's Avatar
dawg
Default RE: derby cover
Bike has to be upright or the fluid is gonna come out. If you have a stock derby cover, it will have an o-ring in the groove (depending on the year) and when you put on a different one, you will have to use a 25416-99C full gasket. The screws are T-27 torx, and don't strip them out. It's simple really
Old Nov 3, 2007 | 08:28 PM
az232's Avatar
az232
I have an 06 Road King. From what I'm reading the gasket only needed on 07 and later touring models. Does that sound right?
Old Nov 3, 2007 | 08:31 PM
Scootr's Avatar
Scootr
They went from the full gasket to the o-ring design in 07 from what I was told. I have an 07 and put on a different derby cover with the full gasket and it works fine.
Old Nov 3, 2007 | 08:50 PM
dawg's Avatar
dawg
You should buy a new gasket, but if you're careful taking off the old one, provided it is the full one, you may be able to get buy using it without any leaks until the next service. I've reused a couple before without any problems.
Old Nov 3, 2007 | 09:18 PM
Arizona's Avatar
Arizona
Easy job, just have the right gasket on hand in case it gets damaged during the swap.
Old Nov 3, 2007 | 11:05 PM
gregm's Avatar
gregm
'05 EGCwith a cardboard disc gasket,I have reused it3 times so far. Just wipe it, and the sealing area off, & make sure to install it right side in, it's marked. Like Dawg said, the bike has to be straight up, not on thejiffy stand.
Old Nov 4, 2007 | 01:10 AM
PapaTravis's Avatar
PapaTravis
I had the exact same question about a year ago, LOL. It is very, very easy. Just make sure you use the correct torx head, a T-27. Take care to not strip out the screw heads, as that will cause you a couple more issues. My '05 had the full round, cardboard gasket. I reused it when I did the derby cover swap, and put a new one on when I did my 5k service. Didn't have any issues to worry about. One bit of advice, if you feel like the head is starting to strip out, stop. Take you bit driver, place it in the screw head, and give it a lite rap with a hammer, and turn it at the same time, to help break the seal. Sometimes, the srews are way to tight.
Old Nov 4, 2007 | 06:14 AM
chappy_2336's Avatar
chappy_2336
Wise man once said "The only stupid question is the one not asked" You got it man, new gasket or oring.
Old Nov 4, 2007 | 08:56 AM
gman's Avatar
gman
also, throw the POS torx bolts away. Go down to Ace Hardware and get chrome allen head bolts to repace the torx bolts. less chance of stripping the heads when removing to change the primary oil, and much easier to work with.
Larry64
Aug 10, 2012 07:28 PM
SoCal Harley
Feb 17, 2012 10:39 PM
Nocturnalnature
Jan 2, 2012 06:28 PM
shoptroll
Oct 30, 2007 08:36 PM
SteelTree
Apr 23, 2007 04:02 PM
