Check Engine light
Old Nov 4, 2007 | 04:27 PM
Nathan918's Avatar
Nathan918
Default Check Engine light
08 Road King
SE Race Tuner
SE Air Cleaner
Rhinehart True Duals
Did all of the work myself a couple of weeks ago. Downloaded the "Generic map" from the Screamin Eagle file. "2008 Touring with air cleaner and racing pipes"
I have rode it several short trips up to the store 10-15 miles. Runs and sounds good. But today I rode it about 30 miles (Temperature has been a little warmer about 70-75 degrees) I tried to set my cruise control.....The light turned green for about a second and then turned Orange Showing that it was not set. I continued to try to set it. It would not. About 2-3 miles up the road The Engine light came on!! I pulled over for a few minutes, shut off the bike, Thinking maybe it was hot or something. (It did not feel any hotter then normal)
Started it back up drove about 5 miles still no Cruise control and then the light came back on. ANY IDEAS??
Old Nov 4, 2007 | 04:57 PM
Nathan918's Avatar
Nathan918
Default RE: Check Engine light
Is there anyway to find out what is tripping the check engine light? AT HOME that is?
Old Nov 4, 2007 | 05:29 PM
rocknrod's Avatar
rocknrod
Ya, that'd tell the tale.
Need to find out since a computer type vehicle.
Old Nov 4, 2007 | 05:43 PM
dawg's Avatar
dawg
Can you check the historical codes?
Old Nov 4, 2007 | 05:45 PM
Shovelhead Bob's Avatar
Shovelhead Bob
As far as the "Canned Map".... It is no where near where it needs to be for a correct running bike.... That particular set-up needs to be tuned in either by a load controlled dynomometer or Twin Scan II+ unit...
That map was designed for a Stock headpipe system, not a true dual headpipe....
As far as your CEL.... In your SERT software you have access to a tool called DATA MODE..... Use it to not only log engine data, but you can also VIEW and CLEAR current and historic DTC's.....
Old Nov 4, 2007 | 07:45 PM
Nathan918's Avatar
Nathan918
Will this "Data Mode" tell me what tripped the ECM to a check engine light?
Old Nov 4, 2007 | 08:47 PM
Shovelhead Bob
ORIGINAL: Nathan918
Use it to not only log engine data, but you can also VIEW and CLEAR current and historic DTC's (Diagnostic Trouble Codes/Check Engine Light).....
That's what I said....... But you will need to invest in the Electrical Diagnostic manual, because after you see what the code is, and what the title of the DTC is, you then need to figure out how to rectify it.... That is where the Service and Electrical Diagnostics manuals come in.....
Old Nov 4, 2007 | 11:33 PM
thatguy's Avatar
thatguy
[size=2]
ECM CODES
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word "none" will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
2007 DTC CODES
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0134 Front 02 Sensor Open
P0154 Rear 02 Sensor Open
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1
Old Nov 6, 2007 | 07:55 PM
Nathan918's Avatar
Nathan918
Thanks "ThatGuy" that info helped a bunch. But the code it gave me was not on the list "PO577" any thoghts?
Old Nov 7, 2007 | 11:16 PM
thatguy's Avatar
thatguy
Sorry, not till I get the '08 manuals... those codes are from an '07Touring - maybe someone else can jump in here and help you on that one.
