WILL 2008FLHX wheels fit on 2004 FLHT ?
25mm is 1 inch so they are the same only difference is if it had abs!
*I am asking another person to physically measure the wheel bearing cup depth. He is in New Zeland The 2000-2007 are 0.983âdeep. I measured the wheel bearing cup depth myself on a surface table.
*The 25mm axle sealed bearings are thinner. When I get some information concerning the actual bearing cup depth I shall inform the original writer of the post. This is potentially very important. I believe the 3/4" & 1" bearing size is 52mm X . For now. please refer to the photo above DAWG until I can get actual facts.
* In answer to the writers post, Minus the hub detail, If the hub is the same bearing cup depth than yu would need 2 X 1" wheel bearings + one x 1" axle wheel bearing collar per wheel. I buy the KLM wheel bearing in bulk so I can supply them to you in the $10-$11 range each bearing. The spacer will cost you around $10 1/2 each at HD. Remember that you can not use the 25mm spacer as it will not fit over your axle.
*BTW, Harley's new 25mm wheel bearing is only single sealed instead of its old double sealed 1" / 3/4" bearings. This means more bearing failure. Never pressure clean the bearings, no matter what size you have.
Not the same. Axle diameter is different. Lower legs from a 07 touring model will not fit an 08. Lower leg is slightly different in axle opening. Sorry!!
