Push button fuel door release
Old Nov 12, 2007 | 12:30 PM
piasspj's Avatar
piasspj
Default Push button fuel door release
I installed a push button fuel door release (Part No. 53842-00B) on my 2008 Ultra. It came with a spring but my bike doesn't have the screw to attach the spring to (as shown in the directions). It still works but it is a little difficult to open the door. Has anyone else installed this accessory?Any ideas on how to get the door to pop open?
Old Nov 12, 2007 | 12:54 PM
MACK's Avatar
MACK
Default RE: Push button fuel door release
It is suppose to come with a spring which is only a v shaped spring. If it was not in the package return it to the dealer for a replacement. There is no other way to make it pop up. remove the rubber cover and see if the screw is under it.
Old Nov 12, 2007 | 12:59 PM
dansflhti's Avatar
dansflhti
maybe the 08s have a different method of securing the tank console...
Old Nov 12, 2007 | 01:02 PM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: MACK
On the '08s you throw the spring away as there is spring in the hinge. There is no screw under the rubber bumpers.
Old Nov 12, 2007 | 01:25 PM
dgoodbmw's Avatar
dgoodbmw
I had and tried the same thing, a takeoff from my 05, it did not want to work on the 08 as there is no way to mount the spring and there is not enough spring in the 08 door to lift cover by itself. I sold it and will wait for the newer version???
Old Nov 12, 2007 | 02:52 PM
chornbe's Avatar
chornbe
Is this kit an electric thing so it only works when the bike is powered on? Does it replace the key? Not sure why you wouldn't want to secure your gas cap otherwise, with the number knuckleheads running around messing with things.
Old Nov 12, 2007 | 03:22 PM
Gutman's Avatar
Gutman
The 53919-04 smooth button fuel door release can be easily adapted.
Old Jan 16, 2008 | 06:09 PM
dgoodbmw's Avatar
dgoodbmw
gutman, would you please add what modifications are needed to make the push button work on 08. thanks
Old Jan 16, 2008 | 06:16 PM
dawg's Avatar
dawg
53842-00B works fine on my 08. I took a dremel and ground a bit off the top of the recess where the black plastic button pops in.
Old Jan 16, 2008 | 06:52 PM
dgoodbmw's Avatar
dgoodbmw
Im sorry, i dont have one in front of me so im at a loss as to what recess you mean. I know that on the button assy there is a plastic triangle that moves with the button, this catches somewhere on the console opening. Is this the area you ground??If i understand even a little, you relieved the tension (clearance) to ease triangle catching console???
