Rewiring passing lamps
Old Nov 14, 2007 | 08:10 AM
t059736's Avatar
t059736
Default Rewiring passing lamps
Good day all. New member just joined. Looking for assistance. I've heard that there is a "simplistic" way to rewire thethe passing lamps to work only through the console switch. In other words,the passing lamps aren't controlled through the use of the headlamps but only through the rocker switch. I took my fairing off last lightto explore the wiring and am somewhat intimidated by what I've seen. I've handle tools before but only to do very simple jobs.I own the shop manualand have reviewed the electrical schematics but I'm still having difficulty identifying theright connectors etc. NO JOB for me is simple, so I would ask that your answers be detailed and any pictures would be GREATLY appreciated.
Thanks for your patience and your help.
Safe riding.
G
Old Nov 14, 2007 | 08:42 AM
YodaddyKeith's Avatar
YodaddyKeith
Default RE: Rewiring passing lamps
I'm thinking you mean you want them to be able to burn whether your headlight is on hi or low beam, and you want to ability to switch them off? Right?
Yep, here is a link to a post that explains exactly how to do it.
https://www.hdforums.com/m_1405927/tm.htm
Old Nov 14, 2007 | 09:39 AM
TexasRedneck's Avatar
TexasRedneck
G, ah originated that thread - if ya got any questions holler - iffen ya need a call, jest PM me a number - be gone the rest of the day, but ah'll holler when ah git back!
Old Nov 14, 2007 | 09:46 AM
MNPGRider's Avatar
MNPGRider
The easiest way to do that is by just taking off the inner faring cap--the one under your ignition switch. All the wires you need are right there behind the switches. Make sure you leave enough "tail" on the yellow wire when you cut it, so that it can be put back to original in the future if so desired by you or the next owner, and make sure you tape or cap the end of the wire, as it is hot whenever your dim lights are on.
Read the directions carefully on how to remove and reinstall the ignition switch.
Old Nov 14, 2007 | 10:09 AM
gambler's Avatar
gambler
Here is a link for you.
Old Nov 14, 2007 | 10:13 AM
61panhead's Avatar
61panhead
I wired mine to operate from the rocker switch, controllable in either high beam or low beam. The hot wire comes off the ignition switch so that I don't forget to turn them off whenI leave the bike. I run them "always on" when riding.
Old Nov 14, 2007 | 01:25 PM
oneshotdog's Avatar
oneshotdog
Thank you very much, i have been looking for that link
Old Nov 14, 2007 | 01:29 PM
oneshotdog's Avatar
oneshotdog
do the passing lamps still shut off when the ignition is turned off, or does the aux swith need to be turned off?
Old Nov 14, 2007 | 01:31 PM
oneshotdog's Avatar
oneshotdog
and is it the same for a road king
Old Nov 14, 2007 | 01:59 PM
YodaddyKeith
Do it as depicted in the link and lights will go out when you turn off ignition no matter what position cowl/fairing switch
For Road King, the switch is on right side of rear of headlight housing, but if wired as per linky it will work the same.
